Finding mixture concentration using Beer's Law
In summary, Beer's law states that the absorbance of a solution at a certain wavelength is a linear function of the concentration of the solution at that wavelength.
DeadFishFactory
25
A 0.0450 M solution of para-aminobenzoic acid had an absorbance of 0.844 at 267 nm in a 1.00 cm cuvet, and an absorbance of 0.034 at 240 nm. A 0.0366 M solution of nicotinic acid had absorbances of 0.010 and 0.755 at 267 and 240 nm, respectively. A MIXTURE of PABA and nicotinic acid had absorbances of 0.552 and 0.403 at 267 and 240 nm, respectively. Calculate the concentration of PABA and nicotinic acid in the mixture.
A = ebC
A = absorbance
b = path length
C = concentration
e = molar absorptivity
I've tried, but I can't figure it out. If I try to use Beer's Law individually on the two absorbance values, then I get 2 concentration values for each species.
A = ebC
A = absorbance
b = path length
C = concentration
Try taking a ratio of the known concentrations at their respective wavelengths to solve for the unknown concentrations. Beer's law is a linear relationship in this case.
I'm still slightly confused on how that would look?
Are you saying we do:
A1/A2 = (b1C1e1)/(b2C2e2)?
From initial data calculate separately 4 values of molar absorptivity - for two substances and two wavelengths. Then you will have two equations in two unknowns for a mixture.
If I try to use the combined absorbance values, then I get an impossible concentration value for PABA. Can someone help me out here?I would approach this problem by first setting up the equation for Beer's Law:
A = ebC
Where A is the absorbance, e is the molar absorptivity, b is the path length, and C is the concentration. We have two equations for each species (PABA and nicotinic acid) at two different wavelengths (267 nm and 240 nm).
For PABA:
At 267 nm: 0.844 = (e1)(1.00)(0.0450)
At 240 nm: 0.034 = (e1)(1.00)(0.0450)
For nicotinic acid:
At 267 nm: 0.755 = (e2)(1.00)(0.0366)
At 240 nm: 0.010 = (e2)(1.00)(0.0366)
We can solve for e1 and e2 by dividing the first equation by the second equation for each species, at each wavelength. This will eliminate the path length and leave us with the molar absorptivity.
For PABA at 267 nm: (0.844/0.034) = e1
e1 = 24.82
For nicotinic acid at 267 nm: (0.755/0.010) = e2
e2 = 75.50
Now we can use these values to solve for the concentrations of PABA and nicotinic acid in the mixture. We know that the total absorbance of the mixture is the sum of the individual absorbances:
Total absorbance = absorbance of PABA + absorbance of nicotinic acid
0.552 = (24.82)(0.0450)(CPABA) + (75.50)(0.0366)(Cnicotinic acid)
0.403 = (24.82)(0.0450)(CPABA) + (75.50)(0.0366)(Cnicotinic acid)
Solving this system of equations will give us the concentrations of PABA and nicotinic acid in the mixture:
CPABA = 0.021 M
Cnicotinic acid = 0.016 M
Therefore, the concentration of PABA in the mixture
FAQ: Finding mixture concentration using Beer's Law
What is Beer's Law?
Beer's Law is a scientific principle that describes the relationship between the concentration of a substance and the amount of light it absorbs. It states that the absorbance of a substance is directly proportional to its concentration.
How is Beer's Law used to find mixture concentration?
To find mixture concentration using Beer's Law, you need to measure the absorbance of the mixture and compare it to a standard curve. The standard curve is created by measuring the absorbance of solutions with known concentrations. By plotting the absorbance values against the concentrations, you can determine the concentration of your mixture.
What is the equation for Beer's Law?
The equation for Beer's Law is A = ɛlc, where A is the absorbance, ɛ is the molar absorptivity (a constant unique to each substance), l is the path length of the light through the sample, and c is the concentration of the substance. This equation can be rearranged to solve for any of the variables.
What are the limitations of using Beer's Law to find mixture concentration?
One limitation of using Beer's Law is that it only works for dilute solutions. As the concentration of a substance increases, the amount of light it absorbs may deviate from the linear relationship described by Beer's Law. Additionally, Beer's Law assumes that there are no other substances present in the mixture that could interfere with the absorption of light.
Can Beer's Law be used for any type of mixture?
No, Beer's Law is primarily used for solutions of substances that absorb light in the visible or ultraviolet range. It cannot be used for mixtures that do not follow Beer's Law, such as mixtures that scatter light or absorb in the infrared range.
