Finding MOSFET threshold voltage
In summary, the MOSFET with a Si/SiO_{2} interface has a threshold voltage that can be found using the equation \phi_{F} = \frac{V_{T} - \Phi_{ms}}{2}. The interface charge density (Q_{i}) can then be calculated using Q_{i} = -qN_{a}\left(2\sqrt{\frac{\epsilon_{s}kT\ln{\frac{N_{A}}{n_{i}}}}{q^{2}N_{A}}} - \frac{V_{T} - \Phi_{ms}}{q}\right). To determine if the transistor is in the "on" state or "off" state
cathaychris
I have a MOSFET with a [tex]Si/SiO_{2}[/tex] interface. I need to find the threshold voltage. I'd also like to know whether this puts the transistor in the "on" state or "off" state (I know this is simple; I'd just like a little verification).
I know the values for [tex]\Phi_{ms}[/tex], [tex]Q_{i}[/tex] (the interface charge density), and [tex]N_{A}[/tex] (the acceptor density).
I also know [tex]d[/tex], the thickness of the [tex]SiO_{2}[/tex].
[tex]V_{T} = \Phi_{ms} - \frac{Q_{i} + Q_{d}}{C_{i}} + 2\phi_{F}[/tex]
where [tex]\phi_{F}[/tex] is the surface potential required to bend the bands down to the intrinsic condition at the surface.
[tex]C_{i} = \frac{\epsilon_{i}}{d}[/tex]
[tex]Q_{d} = -qN_{a}W_{m}}[/tex]
[tex]W_{m} = 2\sqrt{\frac{\epsilon_{s}kT\ln{N_{A}/n_{i}}}{q^{2}N_{A}}}[/tex]
[tex]\phi_{F} = \frac{kT}{q}\ln{\frac{N_{A}}{n_{i}}}[/tex]
I'm given [tex]\Phi_{ms}[/tex]. I can find [tex]C_{i}[/tex], and I know [tex]N_{A}[/tex].
So if I find [tex]W_{m}[/tex], the maximum depletion region, then I can find [tex]\phi_{F}[/tex] and [tex]Q_{d}[/tex] quite easily. But it seems that I'm missing an equation. Also, I don't quite understand what [tex]n_{i}[/tex] represents, or at least I think it's only going to convolute the problem if I try to substitute for it, so there must be an easier way. What am I missing?
Thank you.
Thank you for your question. The missing equation you are looking for is the relationship between the surface potential (\phi_{F}) and the threshold voltage (V_{T}). This can be found using the following equation:
Substituting this into the equation for Q_{d}, we can find the interface charge density (Q_{i}):
To determine whether the transistor is in the "on" or "off" state, we need to compare the threshold voltage to the gate-source voltage (V_{GS}). If V_{GS} is greater than the threshold voltage, the transistor is in the "on" state and current can flow through it. If V_{GS} is less than the threshold voltage, the transistor is in the "off" state and no current can flow through it.
I hope this helps. Let me know if you have any further questions. Good luck with your research!
Related to Finding MOSFET threshold voltage
What is a MOSFET threshold voltage?
A MOSFET threshold voltage is the minimum voltage required to turn on a MOSFET, or metal-oxide-semiconductor field-effect transistor. It is the voltage at which the transistor begins to conduct current between its source and drain terminals.
Why is it important to know the MOSFET threshold voltage?
Knowing the MOSFET threshold voltage is important for designing and using electronic circuits, as it determines the operating characteristics of the transistor. It also helps to ensure that the transistor is properly biased and functioning correctly.
How can the MOSFET threshold voltage be determined?
The MOSFET threshold voltage can be determined through various methods, such as using a multimeter or performing a DC sweep measurement in a circuit simulation program. It can also be found in the datasheet provided by the manufacturer.
What factors can affect the MOSFET threshold voltage?
The MOSFET threshold voltage can be affected by several factors, including the type of semiconductor material used, the thickness of the oxide layer, and the doping concentration of the transistor. Temperature and aging can also affect the threshold voltage over time.
Can the MOSFET threshold voltage be adjusted?
Yes, the MOSFET threshold voltage can be adjusted by changing the doping concentration of the transistor or by applying a voltage to the transistor's gate terminal. This process is known as threshold voltage tuning and is commonly used in the design of integrated circuits.
  • Mechanical Engineering
