Finding net force on object with more than one force
In summary, the conversation discusses the net gravitational force acting on sphere A, given its location and mass along with the location and mass of two other spheres. The equation used is F = GMm/r2 and the attempt at a solution involves finding the force in the vertical and horizontal directions. However, the outcome is incorrect and the person is unsure of where they went wrong.
Planefreak
Three 8kg spheres are located at (0, 1.7), (1.7, 1.7), and (1.7, 0) named A, B, and C respectively. What is the net gravitational force acting on sphere A?
F = GMm/r2
So far I've tried this several ways with no success. I'm not really sure where to begin. Since there is only one acting in the vertical direction I started there. I found the amount of force that the two had towards each other. Then I did some math to determine how much of that is downward. I came up with 3.1388e-10 which is incorrect. I tried the other one in a similar fashion. I found both of the forces then added the two together. Not directly but finding how much is being pulled horizontally and adding to the other. I'm almost 100% sure that I am forgetting something or just messed up somewhere along the way.
They are vectors aren't they?
G1 = ... i + ... j
G2 = ... i + ... j
G1 + G2 = ... ?
To find the net gravitational force on sphere A, we must first calculate the individual forces between sphere A and spheres B and C using the equation F = GMm/r^2, where G is the gravitational constant, M and m are the masses of the two objects, and r is the distance between them. Once we have calculated the individual forces, we can use vector addition to find the net force on sphere A. This can be done by breaking down the forces into their x and y components and then adding them together using vector addition. The result will give us the magnitude and direction of the net force on sphere A. It is important to note that the net force will depend on the distance between the spheres, so if the distances change, the net force will also change. It is also important to consider the direction of the forces, as they may cancel each other out or add up to a larger force. Overall, the net force on sphere A can be found by calculating the individual forces and using vector addition to find the resultant force.
FAQ: Finding net force on object with more than one force
What is net force?
Net force is the overall force acting on an object, taking into account all of the individual forces acting on it.
How do you find the net force on an object?
To find the net force on an object, you must first identify all of the individual forces acting on the object. Then, you can use vector addition to find the resultant force, which is the net force.
What is vector addition?
Vector addition is a mathematical method used to combine multiple forces acting on an object. It involves representing each force as a vector with magnitude and direction, and then adding them together to find the resultant force.
Can the net force on an object be zero?
Yes, the net force on an object can be zero if all of the individual forces acting on the object cancel each other out. This means that the object will remain at rest or continue moving at a constant velocity.
How does the direction of forces affect the net force?
The direction of forces is crucial in determining the net force on an object. If the forces are acting in the same direction, they will add together to create a larger net force. However, if the forces are acting in opposite directions, they will subtract from each other and the net force will be smaller.
