What is the Weight Percentage of Nitrogen in Air?
In summary, air is composed of 78% Nitrogen, 21% Oxygen, and 1% Argon. The atomic weights of Nitrogen, Oxygen, and Argon are approximately 14, 16, and 40 respectively. When calculating the weight of Nitrogen in air, it is approximately 76%, which can also be expressed as 75.4 or 75.5%, depending on rounding. This is determined by multiplying the molar fraction of Nitrogen in air (78%) by the atomic weight of Nitrogen (28), and dividing by the total atomic weight of air (2896). This method is used to calculate the weight percentage of a gas in a mixture.
atim
Air consists of approximately 78% Nitrogen in volume, 21% Oxygen and 1% Argon. The atomic weight of Nitrogen is approximately 14, that of Oxygen 16, and that of Argon 40.
Nitrogen occupies air in weight by
(1) (a) 76% (b) 77% (c)78% (d)79%
I don't know how to calculate, so I just tried
78*28 + 21*32 + 40 = 2896
78*28/2896 = 0.754 = 75.4%
what is the correct method?
That is. The answer comes out very close to 75.5%, so whether you round it to 75 or 76% depends on things like the number of significant figures you took, etc. For the purpose of this question the answer is 76% (Someone has asked this question here before.)
Likes atim
% in Vol only for gases, is a way of give the molar fraction expreseed in %.
You work is correct.
Related to What is the Weight Percentage of Nitrogen in Air?
1. How much nitrogen is in the air?
Nitrogen makes up approximately 78% of the Earth's atmosphere. This means that for every 100 molecules of air, 78 of them are nitrogen.
2. Why is it important to find the weight of nitrogen in air?
Nitrogen is an essential element for life on Earth. It is a key component of proteins and DNA, and is also used in the production of fertilizers and explosives. Knowing the weight of nitrogen in air helps us understand the composition of our atmosphere and its role in supporting life.
3. How do scientists determine the weight of nitrogen in air?
Scientists use a variety of methods to determine the weight of nitrogen in air. One common method is to use a gas chromatograph, which separates the different gases in air based on their molecular weight. Another method is to use mass spectrometry, which ionizes the different gases and measures their mass-to-charge ratio.
4. Does the weight of nitrogen in air change?
The weight of nitrogen in air does not change significantly over time. However, it may vary slightly depending on factors such as altitude, temperature, and humidity.
5. How does the weight of nitrogen in air compare to other gases?
Nitrogen is the most abundant gas in the Earth's atmosphere, making up about 78% of its total weight. This is significantly more than other gases such as oxygen (21%) and carbon dioxide (0.04%).
10K
