Finding Orthogonal Matrices: 2 Solutions and Help
Poetria
267
42
Find four distinct orthogonal 2x2 matrices, each of which has top-left entry equal to ##-\frac {1} {\sqrt{2}}##
Definition of an orthogonal matrix:
##M^T=M^{-1}##
I have found two such matrices:
##\begin{pmatrix} -cos( \frac {\pi} {4}) & sin(\frac {\pi} {4})\\ sin(\frac {\pi} {4}) & cos(\frac {\pi} {4})\end{pmatrix}####\begin{pmatrix} -cos( \frac {\pi} {4}) & -sin(\frac {\pi} {4})\\ -sin(\frac {\pi} {4}) & cos(\frac {\pi} {4})\end{pmatrix}##
Any hint how to find the other two? I have tried several solutions but all of them were wrong.
How ?
Do the explicit matrix multiplication and solve the equations ...
  • Love
Likes Poetria
Oh, ok, I will try. Many thanks. :)
The first matrix is a rotational one: it's easy if you know its properties. The determinant is -1.
Then I have changed the signs of both sines and verified if the second matrix is orthogonal.
BvU said:
How ?
You sure ? I thought those have determinant 1 ...
Likes Poetria
Of course, I am wrong. I confused it with this one:
##\begin{pmatrix} cos(\pi/4) & -sin(\pi/4)\\ sin(\pi/4) & cos(\pi/4)\\\end{pmatrix}##
Anyway a rotational matrix was my point of departure. But I needed a negative cos(pi/4) in the top left corner.
I think you need to reflect a little more.
Likes Poetria
I think so. I will get to the bottom of it sooner or later. :)
Well, I have studied the definition of the orthogonal matrix:
https://mathworld.wolfram.com/OrthogonalMatrix.html
"The rows of an orthogonal matrix are an orthonormal basis. That is, each row has length one, and are mutually perpendicular."
There is a constraint: -1/sqrt(2) in the left top corner of the matrix.
So I have
## \sqrt {(-\frac {1} {\sqrt(2)})^{2}+x^{2}} =1##
##x= \frac {1} {\sqrt(2)}## v ##x= -\frac {1} {\sqrt(2)}##
There are two possibilities for the first row:
##\begin{pmatrix} -\frac {1} {\sqrt(2)} & \frac {1} {\sqrt(2)}\end{pmatrix}##
##\begin{pmatrix} -\frac {1} {\sqrt(2)} & -\frac {1} {\sqrt(2)}\end{pmatrix}##
The dot product of the first and second row has to be equal to zero.
vector (-1/sqrt(2), 1/sqrt(2)) dot vector (y, z) = 0
##\frac {z} {\sqrt(2)} - \frac {y} {\sqrt(2)}=0##
Therefore y=z.
But the length of the second row must be 1.
Therefore ##y=\frac {1} {\sqrt(2)}## v ##y=-\frac {1} {\sqrt(2)}##
The only thing I could do to obtain other matrices is change ##\theta##, e.g. instead of ##\sin(\frac{\pi} {4})## give ##\sin(\frac{9*\pi} {4})## but it's the same numerically.
Not all orthogonal matrices are rotations. In fact, only two are rotations. The others involve rotations and a reflection.
Or, you can simply work through the options for ##\pm \frac 1 {\sqrt 2}## in each entry. That gives 8 possibilities with minus in the first entry to check.
  • Love
Likes Poetria
Wow. :) I got it. :) Wonderful. Many thanks :)
A bit of quiet reflection was all it needed!
Likes Poetria
