Finding other Trig Values from one
  • Thread starter darshanpatel
  • Tags
    Trig
In summary, the conversation discusses finding the other trigonometric function values for theta= arcsin(-5/8). The steps to find these values are to first convert the function to sin(theta)=-5/8 and use the Pythagorean theorem to find the other side of the triangle formed, which is sqrt(39). Since the original function has a negative sine, the quadrant that theta lies in must be determined. The range of the arcsin function is -pi/2 to pi/2, and based on the sign of the sine, theta is determined to be in
darshanpatel
139
The problem gave that:
theta= arcsin(-5/8)
It wants us to find the other five trig function values.
In order to do that, I turned the original function to
sin(theta)= - 5/8
From there I was able to find csc(theta) to be -8/5.
Using the pythagorian theorem I found the other side of the triangle that can be formed to be sqrt(39)
But because sin was negative from the original function, how are you supposed to figure out the quadrant the function lies in, because sin is negative in the 3rd and 4th quadrant.
I understand how to find the other values, I just don't which quadrant it lies in because it would effect the positive and negative signs.
theta= arcsin(-5/8)
sin(theta)= - 5/8
theta= arcsin(-5/8) is not equivalent with sin(theta)= - 5/8. The range of the arcsin function is [-pi/2, pi/2]. So you can decide about the quadrant the angle lies in.
Inverse trigonometric functions - Wikipedia, the free encyclopedia
ehild
ehild
Those two are equivalent because if you do sin45 it equals 1/(sqrt2) and if you do arcsin(1/sqrt2) it equals 45
They are inverse functions.
sinx has no inverse in its whole domain for -∞ to ∞, as it is not a monotonous function. It can be inverted between -pi/2 and pi/2 when it gives the principal values of arcsin function.
ehild
ehild
I do not have any idea what you are saying, but from what you are saying, what would the quadrant be? You are talking about a range from -pi/2 to pi/2 but I don't understand what you mean. We are not supposed to be using calculators so I don't know. Also, we need to find answers such as a side over another side, like the answer to costheta, or tantheta, which would require a conversion from arcsin to sin.
Can you tell me what the quadrants are? And what are the signs of cosine and sine in them?
ehild
ehild
Quadrant 1: sin and cos are both postive
Quadrant 2: sin is only positive, cos negative
Quadrant 3: sin and cos are negative
Quadrant 4: cos is only positive, sin is negative
What angles belong to the individual quadrants? For example 300° belongs to which quadrant?
ehild
ehild
What do you mean by angles? Also, why does it matter?
There are multiple angles per quadrant from 30 degrees to 60 degrees to 45 degrees and so on for each quadrant. Also, the -5/8 doesn't have a special angle like 30, 60, 90 triangles or the 45, 45, 90 triangles
Well, f(x) is a trigonometric function. You speak abut quadrants defined by the sign of sine and cosines. What is the interval for x in the first quadrant, second, third, and so on?
ehild
ehild
I think we are going about this the wrong way. I know for a fact that it is not going to be in the first or second quadrant because the sin was negative. But I don't know weather it is in quadrant 3 or 4 because they both can have negative sines. It might have to do with ranges as you were talking about before. I am thinking quadrant 4 but my gut is saying quadrant 3 and I just want to know how to be able to tell.
theta =arssin(x) returns theta values between -pi/2 and pi/2. Only a monotonous function has inverse. sin(theta) is monotonous in the range -pi/2≤theta ≤pi/2. -pi/2 is the same as 3pi/2, so the domain includes the fourth and first quadrants. According to the sign of the sine, theta can belong to the third or fourth quadrant, but theta in the third quadrant can not be the value of arcsin(-5/8). That means, theta is in the fourth quadrant, where the cosine is positive.
http://www.marlenesite.com/math/trigonometry/images/quadrant.gif
ehild
ehild said:
theta =arssin(x) returns theta values between -pi/2 and pi/2. Only a monotonous function has inverse. sin(theta) is monotonous in the range -pi/2≤theta ≤pi/2. -pi/2 is the same as 3pi/2, so the domain includes the fourth and first quadrants. According to the sign of the sine, theta can belong to the third or fourth quadrant, but theta in the third quadrant can not be the value of arcsin(-5/8). That means, theta is in the fourth quadrant, where the cosine is positive. http://www.marlenesite.com/math/trigonometry/images/quadrant.gif
ehild
Thank you, that makes sense but what do you mean by monotonous functions? I remember learning about things such as sin and tan only go from pi/2 to 3pi/2 and cos is the other way, but I don't really remember.
You can invert a function only in the domain where it is monotonous. Otherwise f(x) can be the same at several different x-es, say f(x1)=f(x2). The inverse function returns the x value where f is given. There are two of them, but a function can have only one value.
So you were taught that the range of arcsin is [pi/2; 3pi/2]? It is all right, sin(x) is monotonous also in that range, although [-pi/2, pi/2] is the usual range. Your calculator will return a negative value for the arcsin of a negative number, and taking the cosine of the result, it will be positive. Try.
[pi/2; 3pi/2] includes the second and third quadrants, so you have to choose the cosine accordingly. Check your notes. Maybe, you need to give both the negative and positive cosines as answer.
ehild
FAQ: Finding other Trig Values from one
1. How do I find the other trigonometric values from just one value?
To find the other trigonometric values (sine, cosine, tangent, cosecant, secant, cotangent) from one value, you will need to use the unit circle or a trigonometric function calculator. Simply plug in the given value and use the corresponding trigonometric function to find the other values.
2. Can I use the Pythagorean identities to find other trigonometric values?
Yes, you can use the Pythagorean identities to find other trigonometric values. For example, if you know the value of sine, you can use the identity sin^2x + cos^2x = 1 to find the value of cosine.
3. What are the steps to find the other trigonometric values?
The steps to find the other trigonometric values from one value are:
  1. Draw a unit circle or use a trigonometric function calculator.
  2. Identify the given value and its corresponding trigonometric function (sine, cosine, tangent, etc.).
  3. Use the unit circle or calculator to find the other trigonometric values by plugging in the given value and using the corresponding trigonometric function.
4. Can I use a right triangle to find the other trigonometric values?
Yes, you can use a right triangle to find the other trigonometric values. However, this method may not be as accurate as using the unit circle or a calculator. You will also need to know the values of the other two sides of the triangle for this method.
5. How can I check if my answers for the other trigonometric values are correct?
You can check your answers by using the inverse trigonometric functions. For example, if you found the value of sine to be 0.5, you can use the inverse sine function (sin^-1) to check if the angle that corresponds to that value is correct. Additionally, you can also use a calculator or online tool to verify your answers.
