Finding out a equation of a plane that is parallel to a plane
In summary, the formula for the equation of a plane parallel to another plane is A(x- x_0)+ B(y- y_0)+ C(z- z_0)= 0. This is equivalent to Ax+ By+ Cz- (Ax_0+ By_0+ Cz_0)= 0. Two parallel planes are perpendicular to the same vectors. In the given example, the vector perpendicular to the plane x- 3y- 2x- 4= 0 is <1, -3, -2>. The equation of the plane perpendicular to this vector and passing through (1, 1, 1) is 1(x- 1)-3(y- 1)-
salistoun
Hi all,
What is the formula of an equation of a plane that is parallel to the plane.
For example the plane is x - 3y -2z -4 = 0 going through a point(1 , 1, 1).
Thanks,
Stephen
The equation of a plane perpendicular to vector <A, B, C>, passing through point [itex](x_0, y_0, z_0)[/itex] is [itex]A(x- x_0)+ B(y- y_0)+ C(z- z_0)= 0[/itex] or, equivalently, [itex]Ax+ By+ Cz- (Ax_0+ By_0+ Cz_0)= 0[/itex].
If two planes are parallel they are perpendicular to the same vectors.
Write a vector is x- 3y- 2x- 4= 0 perpendicular to? What is the equation of the plane perpendicular to that vector containing (1, 1, 1)?
FAQ: Finding out a equation of a plane that is parallel to a plane
How do you find the equation of a plane that is parallel to another plane?
To find the equation of a plane that is parallel to another plane, you need to know the normal vector of the plane and a point that lies on the plane. The normal vector of the parallel plane will be the same as the normal vector of the given plane.
How do you determine the normal vector of a plane?
The normal vector of a plane can be found by taking the cross product of two non-parallel vectors that lie on the plane. This will give you a vector that is perpendicular to the plane, which is the normal vector.
Can a plane be parallel to itself?
Yes, a plane can be parallel to itself. This means that the two planes have the same normal vector and will never intersect.
Is there only one equation for a plane parallel to another plane?
No, there are infinitely many equations for a plane that is parallel to another plane. This is because the equation of a plane can be represented in different forms, such as standard form or vector form.
How does finding the equation of a plane parallel to another plane relate to real-world applications?
Finding the equation of a plane parallel to another plane is important in many real-world applications, such as engineering and architecture. It allows us to understand and manipulate 3D space, which is crucial in designing buildings, bridges, and other structures.
11K
