Finding overlap of fuzzy energy states
In summary: Good luck[;|N_2|^{2}=\frac{1}{15};][;N_2=\frac{1}{\sqrt{15}};]and[;(\Psi , \Phi )=\frac{1}{15}\int_{-\infty}^{\infty}\{ 2[3\psi_1^{*}\psi_1-2\psi_1^{*}\psi_2+3\psi_2^{*}\psi_2]+[2\psi_1^{*}\psi_1+4\psi_1^{*}\psi_2-4\psi_2^{*}\psi_1-2\psi_2^{
wood
23
Recall the definition of the overlap of wave functions Φ and Ψ:
[; (\Psi , \Phi ) = \int\limits_{-\infty}^\infty dx\: \Psi ^{*} (x)\Phi(x);]
Let ψ1(x) and ψ2(x) be unit-normalised wavefunctions representing sharp-energy states with different energies (and hence zero overlap). Use real constants N1, N2 > 0 to normalise the wave functions
[; \Phi (x) = N_1 \{ (\sqrt{3} -i) \psi_1(x) + (-2 + i) \psi_2(x)\} ;]
[; \Psi (x) = N_2 \{ (1 +2i) \psi_1(x) - (1 -2i) \psi_2(x)\} ;]
and find the overlap of the corresponding fuzzy-energy states.
[; (\Psi , \Phi ) = \int\limits_{-\infty}^\infty dx \Psi ^{*} (x)\Phi(x);]
I have normalised Φ and Ψ to get values for N_1 and N_2
[; |N_1|= \frac{1}{3} and\: |N_2|=\frac{1}{\sqrt{5}};]
and this is as far as I can get, as for finding the overlap of the corresponding fuzzy-energy states I have been through my lecture notes and cannot find where to go from here. Do I use the face that that in general
[;N_1= \frac{1}{3} e^{i\theta} and \: N_2=\frac{1}{\sqrt{5}}e^{i\theta};]
and then plug them into the above integral?
Thanks for your help, I am completely lost on this one.
Hi Woody, welcome to PF :smile:! Nice Avatar :wink:.
It looks as if you are using delimiters that my computer does not recognize: ##[;## for open and ##;]## for close instead of ##\#\# ## for textstyle open and close and ## $$ ## for displaystyle open and close
[;(\Psi , \Phi ) = \int\limits_{-\infty}^\infty dx\: \Psi ^{*} (x)\Phi(x);]
1. Homework Statement
$$ (\Psi , \Phi ) = \int\limits_{-\infty}^\infty dx\: \Psi ^{*} (x)\Phi(x)$$
$$ \Phi (x) = N_1 \{ (\sqrt{3} -i) \psi_1(x) + (-2 + i) \psi_2(x)\} $$
$$ \Psi (x) = N_2 \{ (1 +2i) \psi_1(x) - (1 -2i) \psi_2(x)\} $$
2. Homework Equations
$$ (\Psi , \Phi ) = \int\limits_{-\infty}^\infty dx \Psi ^{*} (x)\Phi(x)$$3. The Attempt at a Solution
$$ |N_1|= \frac{1}{3} and\: |N_2|=\frac{1}{\sqrt{5}}$$
$$N_1= \frac{1}{3} e^{i\theta} and \: N_2=\frac{1}{\sqrt{5}}e^{i\theta}$$
First: I get something slightly different for ##N_2##
Then to your real question: no, the ##\theta## does not have to be brought in. Simply write out the overlap definition in full and make good use of what you know from " ψ1(x) and ψ2(x) are unit-normalised", which means " ψ1(x) and ψ2(x) are orthonormal"
Likes wood
Sorry, the second equation should be
[; \Psi(x) =N_2\{2(1+2i)\psi_1(x)-(1-2i)\psi_2(x)\};]
which (I hope ) gives [;|N_2|=\frac{1}{ \sqrt {15}};] (I am presuming you got [; N_2= \frac{1}{\sqrt{10}};] )
Is there another term for overlap? I cannot find anything in my textbook regarding overlap and in my lecture notes we jump from the definition to an example where we just plug the following into the definition
[; \psi_1(x)=\frac{1}{\sqrt{L}}e ^{ip_1/\hbar}\;,\;\psi_2(x)=\frac{1}{\sqrt{L}}e ^{ip_2/\hbar};]
and solve using periodic boundary conditions [; -\frac{L}{2}\leq x\leq\frac{L}{2};]
Thanks
In that case I again get something else for ##N_2## than you :smile: .
Overlap is defined in your problem statement. You have ##\Phi = a\psi_1 + b\psi_2## and ##\Psi = c\psi_1 + d\psi_2## ; carry out the multiplication of the complex conjugate of a sum of two terms times a sum of two terms .
Likes wood
Damn:frown: and thanks
here is my working
[;1=|N_2|^{2}\{2(1+4)+1+4\};]
where
[;1=P_1+P_2=a^{2}+b^{2}+c^{2}+d^{2};]
where a, b, c, d are read directly from c1 and c2
And that is how I get
or do I ignore the 2 out front of Ψ1? and get [;N_2=\frac{1}{\sqrt{10}};]
and back to the problem I am having real problem with :wink:
So I just sub Ψ and Φ into the definition, do all the multiplication and a bunch of stuff will drop out leaving me with a much simpler integral?
Thanks so much for your help.
here is my working
##\Psi(x) =N_2\{2(1+2i)\psi_1(x)-(1-2i)\psi_2(x)\}##
##1=|N_2|^{2}\{2(1+4)+1+4\}##
where
##1=P_1+P_2=a^{2}+b^{2}+c^{2}+d^{2}##
##N_2=\frac{1}{\sqrt{15}}##
or do I ignore the 2 out front of Ψ1? and get ##N_2=\frac{1}{\sqrt{10}}##
Fixed the layout. Thanks for that hint too!
Looks a lot better. And I can simply right-click on the formatted TeX to get back the TeX input, copy it and try to colour the error: ##\
1=|N_2|^{2} \{{\bf 2}(1+4)+1+4\}##
(No I can't, makeup throws off LaTeX: ## 1=|N_2|^{2} (2(1+4)+1+4 )## ## so I boldfaced it ).
You certainly don't ignore a factor in the coëfficiënt !
And you confuse me mightily with ##1=P_1+P_2=a^{2}+b^{2}+c^{2}+d^{2}## (it may well be correct, but P1, P2, c1, c2 ? )
when I expect you to interpret normalization as$$
\int\Psi^*\Psi = 1 \\ \Leftrightarrow
N_2^*N_2\ \int \bigl ( 2(1+2i)\psi_1 - (1-2i)\psi_2\bigr )^* \; \bigl ( 2(1+2i)\psi_1 - (1-2i)\psi_2\bigr ) = 1 \\
\Leftrightarrow N_2^*N_2\ \int \bigl ( 2(1-2i) 2(1+2i) + (1+2i)(1-2i) \bigr ) = 1
(where I used the orthonormality of ##\psi_1## and ##\psi_2## (*) )(*) -- check into that: I think you already know how it works for ##\Psi^*\Psi## ;
same method comes in handy for ##\Psi^*\Phi## too :wink: :
look ma, no integration needed to work out these integrals !
and -- to check you 've mastered it:
find out if (for the most general case) ## \Psi^*\Phi = (\Phi^*\Psi)^*##
as one would expect.
Likes wood
Thanks again, I have manged to get a better answer for N2 this time it is a nice number I I am guessing I did manage to get it right...N2 = 1/5
Now I have done the easy bit, time to get back to the bit that I am struggling with...o_O
Look carefully at what I did for ##\int\Psi^*\Psi## and do the same for the overlap as given in the problem statement (not the =1, though, because this time there will be a different answer :smile:). Write out all the intermediate steps (integral of sum = sum of integrals, bring constant coefficients in front of the ##\int## sign, etc.) and work towards being able to exploit the orthonormality of the ##\psi##.
Thanks so much for your help on this but I think I might have to bail on this. I have a bunch of other work and I think it is a bit crap that our lecturer dumped this assignment on us on the last Friday of the break and it is due first day back, tomorrow, after being so vague on this in lectures. I think I know where it is going after a lot of work if I have time I will have another look tomorrow. Thanks again
Pity. The point I was trying to make that for the overlap it's the same route and no more difficult than the normalization procedure. Not much work either. No integrals to be worked out, since you already know ##\int \psi_1^* \psi_1= 1, \ \ \int \psi_2^* \psi_2= 1 , \ \ \int \psi_1^* \psi_2= \int \psi_2^* \psi_1= 0##. So you only have to deal with the coefficients.
I know I'm close thanks to you. I think it is of the form |c1|2+|c2|2
Just need to work out the c's.
Thanks again
FAQ: Finding overlap of fuzzy energy states
What is meant by "fuzzy energy states"?
"Fuzzy energy states" refer to energy levels or states that are not precisely defined or have a range of possible values. This can occur in certain systems or materials where there is a degree of uncertainty or variability in the energy levels of particles or molecules.
How do you find the overlap of fuzzy energy states?
Finding the overlap of fuzzy energy states involves analyzing the energy levels of the particles or molecules in question and determining the range or probability distribution of their energy states. Then, using mathematical methods such as integration or statistical analysis, the overlap of these energy states can be calculated.
Why is it important to find the overlap of fuzzy energy states?
The overlap of fuzzy energy states is important in understanding the behavior and properties of systems or materials. It can provide insights into the stability, conductivity, and other characteristics of these systems, which can have practical applications in fields such as materials science and quantum chemistry.
What techniques are commonly used to find the overlap of fuzzy energy states?
Some commonly used techniques to find the overlap of fuzzy energy states include density functional theory, molecular dynamics simulations, and quantum mechanical calculations. These methods involve complex mathematical models and algorithms to accurately determine the energy states and their overlap.
Can the overlap of fuzzy energy states be experimentally measured?
Yes, the overlap of fuzzy energy states can be experimentally measured using techniques such as spectroscopy or diffraction. These methods involve analyzing the interaction of particles or molecules with different energy states and can provide valuable data on the overlap and distribution of these states.
