Finding parametric representation of a surface
In summary: You can see that the ##x##, ##y##, and ##z## coordinates are all within the bounds of the first octant, and that the ##ϕ## coordinate is also within the bounds.I will now redraw the same picture, but with ##\theta## values that give the points in the first octant the values shown in the following table.I have indicated a general ##\theta## and the green lines are in the plane generated......by the equation y=5.You can see that the ##x##, ##y##, and ##z## coordinates are all within the bounds of the
uzman1243
80
I am trying to find parametric representation of the right surface of a sphere which was cut along the line y=5.
x^2 + y^2 + z^2 = 36
This is an equation of a sphere with radius given by:
r^2 = 36
r=6
x= r cos(theta)sin(phi)
y= r sin(theta)sin(phi)
z= r cos(theta)
sub x,y,z into original equation to get function with theta,phi as parameters.
Have is the correct way to start? if so, how do I proceed?
In three dimensions, y = 5 is a plane. It is 5 units to the right of the x-z plane.
r^2 = 36
r=6
z= r cos(theta)
I'm not sure how much help this will be, but the y coordinate lies between 5 and 6, and the x and z values range between ##-\sqrt{11}## and ##\sqrt{11}##, depending on the particular point on the portion of the sphere.
r^2 = 36
r=6
That is the equation of the sphere in spherical coordinates, except it's best to use the standard ##\rho## instead of ##r## for the radius. So you have ##\rho = 6##, which I have put in below for you:
x= 6cos(theta)sin(phi)
y= 6sin(theta)sin(phi)
z= 6cos(theta)
and you just need to know the ranges for ##\phi## and ##\theta## to get the portion of the sphere to the right of the plane ##y=5##.
Draw the circle and straight line in the ##yz## plane giving the trace of these two surfaces. You should be able to figure out from that picture what values of ##\phi## give the portion of the circle to the right of the plane. Same idea in the ##xy## plane for ##\theta##.
Can you explain this part a little more?
I'm not sure what LCKurtz meant by his reply, since you're dealing with a sphere rather than a circle. The plane y = 5 slices a piece of the sphere, and intersects the sphere to form a circle.
So how do I proceed?
Follow what LCKurtz said:
LCKurtz said:
you just need to know the ranges for ϕ and θ to get the portion of the sphere to the right of the plane y=5.
Yes. I don't understand what that means
Have you drawn a sketch of the region sliced off the sphere?
The plane y = 5 intersects the sphere in a circle whose center is at (0, 5, 0) and whose radius is ##\sqrt{11}##. What are the coordinates of the highest and lowest points on this circle? That should give you an idea of the range of ##\phi##.
What are the coordinates of the points that are furthest in the direction of the x-axis, and the furthest in the direction of the negative x-axis? These points should give you the range of ##\theta##. I believe that's what LCKurtz was talking about.
Here's what I mean by the trace of the surfaces in the zy plane. (Standard usage of trace):
You should be able to figure out the two values of ##\phi## from the two arcs. A similar trace in the xy plane should help you figure out the range for ##\theta##. Just don't expect the angles to be one of the "standard" angles like ##\pi/6##.
[Edit, added]: It may be a bit more complicated in that the limits of ##\phi## may depend on the value of ##\theta##. Actually, that does happen. I will add to this tomorrow.
OK, I think we need to do a restart on this problem. I will begin with a new 3D picture of just the first octant portion of this problem.
I have indicated a general ##\theta## and the green lines are in the plane generated by that ##\theta## as ##\phi## and ##\rho## vary. Note that as ##\phi## varies from ##0## to ##\pi /2## the end of the ##\rho=6## line sweeps along the green arc ABC. Point B is the place where ##\phi## begins to hit the part of the sphere to the right of ##y=5##. The plane ##y=5## is outlined with the purple lines. Notice that if ##\theta## were ##\pi / 2## then ##\phi## would only sweep out the arc AD before hitting the plane ##y=5##. That is a shorter arc than AB so the lowest value of ##\phi## to hit the plane depends on ##\theta##. To get the relation between ##\phi## and ##\theta##, look at the point ##B =(6,\theta,\phi)##. That point lies on the plane ##y=5##. The spherical coordinate equation for ##y## in general is ##y=\rho\sin\phi\sin\theta##. Applying that to this point gives ##5 = 6\sin\phi\sin\theta## so ##\sin\phi =\frac 5 {6\sin\theta}##. So, finally, the dependence of ##\phi## on ##\theta## is$$
\phi = \arcsin\left(\frac 5 {6\sin\theta}\right)$$So, in this picture, depending on what ##\theta## is, we would have$$
\arcsin\left(\frac 5 {6\sin\theta}\right)\le \phi \le \frac \pi 2$$Of course, for the full problem, ##\phi## wouldn't stop at ##\pi /2##.
In the picture, ##\alpha##, which is angle GOF in the xy plane, would be the min value of ##\theta## and its max would be ##\pi/2##, but it wouldn't stop there for the non-first octant part. I have deliberately not done more than the first octant to leave the OP something to do, yet I pretty much couldn't do less and explain the problem clearly.
BUT, and this is the real lesson here, while this is a great exercise for doing complicated limits and gives a perfectly good parameterization, it is NOT the best way to work this problem.
To see this, think about how much simpler this problem would have been if it had asked for the parameterization of the part of the sphere above the plane ##z=5## instead of to the right of the plane ##y=5##. If you set that problem up in spherical coordinates, the ##\theta## and ##\phi## limits are easy, constant, and don't depend on each other. So think about solving that problem. Once you have that solved, you only have to rename the variables so instead of using the ##z## axis for the azimuth angle, use the ##y## axis.
Related to Finding parametric representation of a surface
1. What is a parametric representation of a surface?
A parametric representation of a surface is a mathematical expression that defines a surface in three-dimensional space using one or more parameters.
2. Why is it important to find a parametric representation of a surface?
Finding a parametric representation of a surface allows for easier mathematical analysis and manipulation of the surface, making it easier to study and understand its properties.
3. How do you find the parametric representation of a surface?
The parametric representation of a surface can be found by expressing the x, y, and z coordinates of the points on the surface in terms of two independent parameters, usually denoted by u and v.
4. What is the difference between a parametric representation and an implicit representation of a surface?
A parametric representation of a surface gives the coordinates of each point on the surface in terms of parameters, while an implicit representation defines the surface as the set of points satisfying a single equation in x, y, and z.
5. Can any surface be represented parametrically?
Yes, any surface can be represented parametrically as long as it can be defined by a set of coordinates in three-dimensional space.
  • Topology and Analysis
