Finding Particular Solutions of y''+10y'+25y= 32xe^(-x)
  • Thread starter wshfulthinker
Thus, in the case of f(x)=32x^2 e^{-x}, you'd try a polynomial of degree 2 down --- i.e., yp = A + Bx +Cx^2 e^{-x}.
wshfulthinker
Consider the differential equation:
y''+10y'+25y= f(x)
Find a particular solution if f(x) = 32xe^(-x)
I already did the general solution when f(x)=0 and that is Ae^(-5x) + Bxe^(-5x)
I tried yp=axe^(-x) and got a= 4x+2 which is wrong
The answer is (2x-1)e^(-x)
does anyone know what particular solution i can try in order to get the answer?
Thanks
If f(x) had been 32e-x, you would want to try yp = Ae-x. Since f(x) = 32xe-x, you want your particular solution to be yp = Ae-x + Bxe-x.
If f(x) had been 32x2e-x, you would try a particular solution of the form yp = Ae-x + Bxe-x + Cx2e-x. There's a reason for all of this, but I'll leave that for your instructor.
BTW, this is hardly a Precalculus question. You should have posted it in Calculus and Beyond.
Hi, thankyou so much for your reply. I tried it and it worked! i shall write it down and remember that forever now!
Also, sorry about posting in the wrong section! I can't believe i did that because i took so long to check that my post was right.. i guess i forgot to check if i had clicked on the right section..! Thankyou so much though.
Generally speaking when a "right hand side" involves an [itex]n^{th}[/itex] power of x, you should try a polynomial of degree n down.
FAQ: Finding Particular Solutions of y''+10y'+25y= 32xe^(-x)
What is the general method for finding particular solutions of a second-order differential equation?
In order to find a particular solution of a second-order differential equation, we can use the method of undetermined coefficients. This involves guessing a particular solution based on the form of the non-homogeneous term and then plugging it into the equation to solve for the unknown coefficients.
How do we determine the form of the particular solution for a given non-homogeneous term?
The form of the particular solution depends on the form of the non-homogeneous term. For example, if the non-homogeneous term is a polynomial, the particular solution will also be a polynomial. Similarly, if the non-homogeneous term is an exponential function, the particular solution will be a linear combination of exponential functions.
Can we have more than one particular solution for a given differential equation?
Yes, it is possible to have more than one particular solution for a given differential equation. This can happen when the non-homogeneous term has multiple forms, such as a polynomial and an exponential function.
How do we handle complex solutions when finding particular solutions?
If the non-homogeneous term has complex roots, the particular solution will also have complex terms. In this case, we can use Euler's formula to convert the complex terms into trigonometric functions, which can then be solved for their coefficients.
Can we use the method of undetermined coefficients for all types of non-homogeneous terms?
No, the method of undetermined coefficients can only be used for certain types of non-homogeneous terms, such as polynomials, exponential functions, and trigonometric functions. For other types of non-homogeneous terms, we may need to use other methods, such as variation of parameters or the method of annihilators.
