Finding percent sulfuric acid by mass
In summary, to determine the percent sulfuric acid by mass of a 1.49m (molality) aqueous solution of H2SO4, you would use:-molarity (mol solute / liter of solution)-molality (mol solute / mass solvent)-percent by mass
leroyjenkens
616
49
Determine the percent sulfuric acid by mass of a 1.49m (molality) aqueous solution of H2SO4.
H2SO4 has a molar mass of about 98 g/mol
Percent by mass = mass solute / mass solution
Molarity = mol solute / liter of solution
Molality = mol solute / mass solvent (in kg)
It doesn't seem like there's enough information. This is practice problem B, so I'm not sure if it wants me to use information from practice problem A or not. On the last page, I used information from A to solve B and got the wrong answer, so I don't think we need any information from A. It just seems like any equation arrangement I make, I have 2 unknowns.
1.49 = mol solute / kg solv
2 unknowns
% by mass = mass solute / mass solution * 100
There's 3 unknowns in this one. What other equations are there that I could use?
And do I have to assume a volume of the solution for this? Like 1 liter?
Thanks.
2 unknowns
Thanks.
Even if I had to assume, I would assume that mass of solvent is 1kg.
You can even do it by considering the mass of solvent as x and find the mass of the solute in terms of x.
I assumed the mass of solvent was 1kg and got an answer of 14.6%. The answer is 12.8%. I did everything right.
If I had assumed the mass of the solvent was 2kg, I would have gotten a different answer. So how can I get the correct answer by assuming values?
I can't point out the error until you show your calculations. :)
That definitely means you are doing something wrong. But as Pranav-Arora said, it is impossible to tell what not seeing your approach.
I got 12.7% (12.741) when using 98 for molar mass, and 12.8% (12.751) when using 98.08 for molar mass.
Good point.
Alright, I'll start from scratch with the information I have:
Molality = 1.49 = mol solute / kg solvent
% H2SO4 by mass = mass solute / mass solution *100%
Molar mass of H2SO4 = 98g/mol
Molarity = mol solute / L solution (not even sure if I need this)
Let's say I have 1 liter of solution. The solution is a combo of H2SO4 and H2O.
Molar mass of H2O is 18.
And this time I'm using the table that my teacher taught us to use. We fill in the table with all the information we know, and then we figure out using the information we know, to fill in the rest.
Ok so the stuff I know is above, and here's another thing I know.
1g of water = 1 mL
So I convert that to 1000g water per liter, multiply that by 1 mol / 18 g to give me the mols of water, because I'm assuming I'm using just 1 liter of water. I use the equation 1.49 = mol solute / kg solv, plugging in 1kg of my solvent to get 1.49 as my moles of H2SO4. Using that an the molar mass of H2SO4 by multiplying 1.49moles * 98g/mole = 146.02g. So I have mass of both solute and solvent, so I add those together to find mass of solution, which is 1146.02 and use equation %mass of H2SO4 = 146.02 / 1146.02 * 100% to get the answer of 12.74148793%, which is pretty close to the answer in the back of the book, which is 12.8%. I guess they made a mistake by not keeping enough sig figs throughout the calculations? Or did I make a tiny mistake?
Thanks. (I just figured all this out. I didn't make this thread because of a 0.1 difference between my answer and the book.)
Oh ok thanks. I guess I got it right. I forgot the molar masses of those chemicals wasn't exactly 98 and 18.
Will you ever use it?
Sounds like a homework template. Not without a reason.
1g of water = 1 mL
Have you used any of the information posted earlier? :-p
My bet is they calculated using exact data and forgot to check for rounding errors. In this particular case last digit of the final answer happens to be very sensitive to data, because of the rounding. Completely accidental.
Have you used 18 in your calculations?
I guess I did a roundabout way of doing this problem. Oh well, it's good practice, I guess. We have a quiz tomorrow where we have to fill in the tables with all the information, so even if I don't need the information for the problem, we're expected to fill in all the information into the tables.
Thanks for the help.
The density of the solution would help. You want to convert 1000 milliliters of the solution to grams of solution.
No - you are given molality, not molarity.
And... poster perhaps still has an imperfect understanding of the pertinent differences between the two. That is the purpose of exercises like this one.
Related to Finding percent sulfuric acid by mass
1. How do you find the percent sulfuric acid by mass in a given solution?
To find the percent sulfuric acid by mass in a solution, you will need to know the mass of the sulfuric acid in the solution and the total mass of the solution. The percent sulfuric acid by mass can then be calculated by dividing the mass of sulfuric acid by the total mass of the solution and multiplying by 100.
2. Why is finding the percent sulfuric acid by mass important?
Finding the percent sulfuric acid by mass is important because it allows us to accurately determine the concentration of sulfuric acid in a solution. This information is crucial in various applications, such as in industrial processes, laboratory experiments, and chemical analyses.
3. What is the formula for finding the percent sulfuric acid by mass?
The formula for finding the percent sulfuric acid by mass is: (mass of sulfuric acid / total mass of solution) x 100. This formula is based on the concept of mass percent, which expresses the mass of a particular component in relation to the total mass of the solution.
4. Can the percent sulfuric acid by mass be greater than 100%?
No, the percent sulfuric acid by mass cannot be greater than 100%. This is because the percent by mass is a ratio of the mass of sulfuric acid to the total mass of the solution, and it cannot exceed 100% of the total mass.
5. How can I measure the mass of sulfuric acid in a solution?
The mass of sulfuric acid in a solution can be measured using a balance or scale. First, measure the mass of the empty container holding the solution. Then, add the solution and measure the total mass of the solution and container. The difference between these two measurements is the mass of the solution, and the mass of the sulfuric acid can be calculated by subtracting the mass of the empty container from the mass of the solution and container.
9K
