Finding points on a tangent line
In summary, the problem is to find the point(s) on the graph of the function where the tangent line has a slope of -4. After deriving the function, the solution is to set the equation to the given slope and solve for the x-values. However, there was a mistake made in solving the quadratic equation, resulting in an incorrect x-value. The correct point is (0,8).
Vandella
25
Find the point(s) on the graph of the function at which the tangent line has the indicated slope. (If an answer does not exist, enter DNE.)
g(x) = (1/3)x^3 - (1/2)x^2 - 4x +8
mtan=-4
3. The Attempt at a Solution
firstly i derived g(x) to give x^2-x-4
as tangent line = -4 substituted into equation to give x^2-x-4=-4
manipulated to get x^2-x=0
that gave me x=0 or x=-1
used those values in original function to find y values
points i obtained were (0,8) and (-1,67/6)
when i enter these with lowest x value first it says i am wrong please help
Since this is just a silly brainfart mistake I'm going to give you the answer, x=-1 is not a solution, you made a silly mistake when you solved the quadratic.
ahhh i can't believe i missed that
thanks
FAQ: Finding points on a tangent line
How do you find the equation of a tangent line to a curve?
The equation of a tangent line to a curve can be found by using the derivative of the curve at the point of tangency. The slope of the tangent line will be equal to the derivative at that point. To find the y-intercept of the tangent line, substitute the coordinates of the point of tangency into the equation and solve for the y-intercept.
What is the difference between a tangent line and a secant line?
A tangent line touches a curve at only one point, while a secant line intersects the curve at two points. The slope of a tangent line is equal to the derivative of the curve, while the slope of a secant line is the change in y over the change in x between the two points of intersection. As these two points get closer together, the secant line becomes more like the tangent line.
How many points of tangency can a curve have?
A curve can have multiple points of tangency, depending on its shape. For example, a circle has an infinite number of points of tangency, while a straight line has no points of tangency.
Can a tangent line be horizontal?
Yes, a tangent line can be horizontal. This occurs when the slope of the curve at the point of tangency is equal to 0. In this case, the equation of the tangent line would simply be y = the y-coordinate of the point of tangency.
What is the significance of finding points on a tangent line?
Finding points on a tangent line allows us to approximate the behavior of a curve at a specific point. It can also help us find the slope of the curve at that point, which is useful in many applications such as optimization and curve sketching.
