MHB Finding Points Parallel to a Plane
The vector P = (1,2,-1) is parallel to the plane defined by the equation 7x + 2y + kz = 5, leading to the determination of the value of k. To find k, the normal vector of the plane, represented as <7, 2, k>, is used in the equation for points parallel to the plane. The calculation shows that substituting the point (1,2,-1) into the plane equation yields 11 - k = 5. Solving this equation results in k being equal to 6. The discussion emphasizes the relationship between a point and a plane's normal vector in determining parallelism.
Guest2
If the vector $P = (1,2,-1)$ is parallel to the plane $7x+2y+kz = 5$, then what's the value of $k$?
Mathematics news on Phys.org
Do you know how to find the general formula for points parallel to a plane?
So we find another plane parallel to this in which the point $(1,2,-1)$ lies?
I think $\mathbf{n} \cdot (\mathbf{x-x_{0}}) = 0$ so
$<7,2,k><x-1,y-2,z+1> = 0 \\
\implies 7x+2y+kz+k = 11 \\
\therefore 11-k = 5 \\
\implies k = 6.$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
21K
