A Finding potential of a dipole outside of a sphere
The discussion centers on calculating the potential of an electric dipole near a grounded conducting sphere. The dipole is positioned at a distance B from the sphere's center, with its orientation tangent to the sphere's surface. One suggestion involves using the method of images, reflecting the dipole across the sphere's surface to analyze the resulting field. The complexity of the problem increases with the dipole's size relative to the sphere's diameter, which hasn't been specified. Participants encourage exploring the image charge method for a clearer understanding of the potential outside the sphere.
nicholasBourbaki
TL;DR Summary
What is the potential of a dipole outside of a sphere when the orientation of the dipole is tangent to the sphere?
Hey guys! I am currently tackling the following problem: An electric dipole P is kept close to a conducting grounded sphere of radius A -assume a distance B between the center of the sphere and dipole. What is the potential of the dipole outside of the sphere when the orientation of the dipole is tangent to the sphere?
I tried finding the green function of the structure and then tried to find the electric dipole in terms of two volume charged density and finally tried to find the potential using these two values. However that did not get me anywhere. I would appreciate if someone could point me to the right direction.
Welcome to PF.
Just an idea, but I would look at the reflection of the dipole in the conductive-mirror surface of the sphere. Analyse the dipole and its image. The image of the dipole is distorted by the surface curvature, and will be reversed.
There may be a simplification, but you have not specified the relative length of the dipole to the diameter of the sphere.
If you model the dipole as a plus charge and a minus charge, a distance d apart, you can find the field of each charge by the usual image calculation.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
