Finding potential of a given wavefunction in spherical polar
In summary, the conversation discusses the ground state wavefunction of a system in spherical polar coordinates, given by Ψ (r,θ, φ)= (A/r) [exp (-ar) - exp (-br)], and its normalization and potential behavior. The conversation also mentions applying the time-independent Schrödinger equation to calculate the potential, with the constants a, b, A, and k. The process of finding the potential is described, but it is not clear whether it is possible to find the potential.
sudipmaity
50
The ground state wavefuntion
coordinates is given by:
exp (-br)] where a, b, A are
constants.
i) Determine A as a function
of a and b, so as to normalize
the wavefuntion.
ii) From Schrödinger equation
find V (r) in terms of a and b
iii) From potential behaviour
find the energy eigenvalue if
b=6a in the ground state.
integral |ψ|^2 dτ=1
Hψ=Eψ
H= -hbar/2m grad^2 + V
I integrated | ψ|^2 r^2 dr
sinθ dθ dφ =1
I found A= {1/a-b}[ab* (a
+b) /2π]^(1/2)
After putting the wavefuntion
in time independent
schrodinger's (Hψ=Eψ)the
calculation is getting pretty
elaborate.Cant figure out how
to find the potential.This is a
University exam question and
each of the three question
carried 2 marks.please help
me calculate the potential.
Please show your working when you applied the schrodinger equation.
let 2m/hbar^2=k
then -1/k grad^2 ψ +Vψ=Eψ
or grad^2 ψ =k (V-E)ψ
given wavefuntion is independent of θ, φ
so in spherical polar grad^2= (1/r^2)δ/δr (r^2 δ/δr)
I am getting (r^2 δ/δr)= r [b exp(-br)-a exp (-ar)] - [exp (-ar)-exp (-br)]
next differenting the above again w.r.t r and multipying with 1/r^2
grad^2 ψ= ( 1/r) [a^2 exp (-ar)- b^2 exp (-br)]
'A' depends on a and b which are constants .So I guess A will cancel out.
So now my TISE looks like
( 1/r) [a^2 exp (-ar)- b^2 exp (-br)]=k (V-E) ( 1/r) [exp (-ar)- exp (-br)]
What should I do after this??
Can somebody at all confirm whether it is possible to find the potential?
utube
Related to Finding potential of a given wavefunction in spherical polar
1. What is a wavefunction in spherical polar coordinates?
A wavefunction in spherical polar coordinates describes the behavior of a quantum particle in a three dimensional space, taking into account the distance from the origin, the angle from the z-axis, and the angle from the x-axis.
2. How do you find the potential of a given wavefunction in spherical polar coordinates?
To find the potential of a given wavefunction in spherical polar coordinates, you need to use the Schrödinger equation, which involves solving for the Hamiltonian operator and applying it to the wavefunction.
3. Can the potential of a given wavefunction in spherical polar coordinates be negative?
Yes, the potential of a given wavefunction in spherical polar coordinates can be negative. This means that the particle is experiencing an attractive force towards the origin.
4. How does the potential of a given wavefunction in spherical polar coordinates affect the behavior of a quantum particle?
The potential of a given wavefunction in spherical polar coordinates determines the energy levels and the probability of finding the particle at different points in space. It can also affect the shape and size of the wavefunction.
5. Can the potential of a given wavefunction in spherical polar coordinates change over time?
Yes, the potential of a given wavefunction in spherical polar coordinates can change over time if the system is not in a stationary state. This means that the energy of the particle is changing and the wavefunction is evolving accordingly.
