MHB Finding Primitive Roots Modulo 169: Is There a Smarter Way?
  • Thread starter Thread starter tda1201
    Primitive Root
To find a primitive root modulo 169, it is established that either 2 or 15 can serve as a primitive root. Testing 2 is the first step; if it does not work, then 15 is the alternative. The discussion emphasizes that checking all orders dividing φ(13²) is unnecessary; instead, one should verify orders derived from φ(13²) divided by distinct primes. Since 2 is a primitive root mod 13, its order mod 169 will either be 12 or 156, simplifying the verification process. Ultimately, confirming whether 2 is a primitive root mod 169 eliminates the need to check other powers.
tda1201
How can I find a primitive root modulo 169?
I found the primitive roots mod 13 by testing 2, and then concluding that any 2^k with (k, 12)=1 would do. So that gave me 2, 6, 7 and 11. But modulo 13 I have no idea how to start.. I’m sure there’s a smarter way than trying 2^the orders that divide phi(13^2)..?.
Mathematics news on Phys.org
Hi tda, and welcome to MHB. You might be interested in this link, which tells you that the answer to your question is either $2$ or $2+13=15$. That still leaves you with the work of testing to see if $2$ works. If it does not, then $15$ does.
There is no simple method. You can cobble up together some basic theories on primitive roots, find a bit of a rough upperbound (although none is known to be useful for small cases) and some modular exponentiation to get a fast enough algorithm.
As Opalg there indicated, that either 2 or 15 is primitive root modulo 169, can easily be found for this case. Try proving the former and then the later if it doesn't work.
You don't have to check all the orders that divide $\phi(13^2)$.
It suffices to check each of the orders that are $\phi(13^2)$ divided by one of the distinct primes it contains.
In your case:
$$\phi(13^2)=2^2\cdot 3 \cdot 13$$
So the orders to verify are:
$$2\cdot 3 \cdot 13,\quad 2^2 \cdot 13, \quad 2^2\cdot 3$$
Nice!
From that link we also get that since 2 is a primitive root mod 13, it follows that the order of 2 mod 169 is either (13-1) or 13(13-1).
So if $2^{13-1} \not\equiv 1 \pmod{169}$ that means that 2 has to be a primitive root mod 169. Or otherwise 15 has to be.
In other words, no need to check any of the other powers.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
