Finding principal axes of electromagnetic stress tensor
In summary: I just explicitly wrote out the first component of the result as ##M_{11}C_1+M_{12}C_2+M_{13}C_3## where ##\bar{C}## is the cross product, writing ##C_1=E_2B_3-E_3B_2## etc, inserted the explicit expressions for each ##M_{1j}## in terms of E and B, expanded it using the distributive law and then started cancelling. It didn't take long.By the way, it should be -1/2. I made a mistake working out the trace. Your method of
Dazed&Confused
191
In a certain system of units the electromagnetic stress tensor is given by [itex] M_{ij} = E_iE_j + B_i B_j - \frac12 \delta_{ij} ( E_kE_k + B_kB_k) [/itex]
where [itex] E_i [/itex] and [itex] B_i [/itex] are components of the 1-st order tensors representing the electric and magnetic fields [itex] \bar{E} [/itex] and [itex] \bar{B}, [/itex] respectively.
b) For [itex] |E| = |B| [/itex] (but [itex] \bar{E} \neq \bar{B} [/itex]):
show that [itex] \bar{E} \pm \bar{B} [/itex] are principal axes of the tensor [itex] M [/itex].
I get that this is related to diagonalisation of matrices, but I am not sure how to apply that knowledge in this case. The lecture notes I have make no mention of principal axes or diagonalisation. Not at all sure how this is to be done. Any hints?
To say that ##
\bar{E} \pm \bar{B}
## are principal axes of ##M## means they are eigenvectors of ##M##. So what you have to prove is that there exist scalars ##\lambda_1,\lambda_2## such that:
$$M(\bar{E}+\bar{B})=\lambda_1(\bar{E}+\bar{B})$$
and
$$M(\bar{E}-\bar{B})=\lambda_2(\bar{E}-\bar{B})$$
By the way, your formula for ##M_{ij}## is wrong. It uses a subscript ##k## that is undefined.
Likes Dazed&Confused
There's probably an implied summation since ##k## appears twice in each term.
Thanks. Yes they are an implied summation.
For ## \bar{E} + \bar{B} ##, the ## \lambda## I got was ##E_kB_k##.
For ## \bar{E} - \bar{B}##, the eigenvalue was ##-E_kB_k##. I'll post the other parts of the question:
c) determine the third principal axis and
d) find all principal values
I did part d) by finding the trace of the tensor which is the sum of the eigenvalues ( I think! ), so the last principal value is ##E_kE_k##. Is this correct?
The matrix M and the first two eigenvectors and eigenvalues are all symmetric between B and E, so it seems unlikely that the third eigenvalue would break that symmetry, since any derivation that gives that could equally give ##B_kB_k##.
For (c) you could use the fact that eigenvectors of a linear operator must all be mutually orthogonal.
I used the fact that ##E_kE_k = B_kB_k##, since this course section is mainly about Cartesian tensors.
I forgot about that bit. Fair enough then.
A symmetric expression for what you've used is ##\frac{1}{2}(|\bar{E}|+|\bar{B}|)##.
So if I take the cross product of the two vectors, and simplify, you get ##\bar{E} \times \bar{B}##. I'm not getting the previous eigenvalue with this.
Are you sure? The cross product works for me. When I left-multiply it by M, I don't get an eigenvalue exactly like what you wrote in post 5, but not very different.
Well I used the expression ## (\bar{E} \times \bar{B})_j = \epsilon_{jlm}E_l B_ m##.
Strange, but I got ## -\frac16 ( |E|^2 + |B|^2) ##
I got ##-\frac{1}{2}(|\bar{E}|+|\bar{B}|)##. When we calculate the first component of the vector multiplication we get that eigenvalue times the first component of ##\bar{E}\times\bar{B}## from the ##\delta## term in ##M##, and we get twelve other terms from the other two terms in ##M##, which match up neatly into six pairs each of which cancels out. Since both the cross product and the matrix are symmetrical between the three dimensions, we know the same must happen for the other two components.
I'll write it out: ##(E_iE_j + B_iB_j) \epsilon_{jlm}E_lB_m -\frac12 \epsilon_{ilm}(E_jE_j + B_jB_j)E_lB_m ##. I multiplied this by ##\epsilon_{ilm}## to get. ##2(E_jE_j + B_jB_j)E_lB_m - 3 (E_jE_j + B_jB_j)E_lB_m.## The right hand side equals ## 6\lambda E_lE_m##.
I've never used ##\epsilon_{jlm}## notation. I find it unnecessarily confusing, and it doesn't seem to shorten things in a helpful way.
By the way, it should be -1/2. I made a mistake working out the trace. Your method of finding the last eigenvalue looks like a nightmare to me, but I can't find the mistake in mine.
It should be ##M_{ij}x_j = \lambda x_i##, right?
Something must be wrong with my previous method, but I can rewrite ## (E_iE_j + B_iB_j) \epsilon_{jlm}E_lB_m## as ##E_i B_m
\epsilon_{mjl} E_jE_l + B_i E_l \epsilon_{lmj} B_m B_j ## which equals ##\bar{E} (\bar{B} \cdot (\bar{E} \times \bar{E})) + \bar{B} (\bar{E} \cdot (\bar{B} \times \bar{B})) = 0##.
That's right.
Does it all work out now?
I would still like to understand where my previous attempt went wrong, but I'll ask the lecturer this. Thanks for all the help.
Related to Finding principal axes of electromagnetic stress tensor
1. What is the electromagnetic stress tensor?
The electromagnetic stress tensor is a mathematical representation of the stress and strain caused by electromagnetic fields. It is a 4x4 matrix that describes the distribution of energy and momentum in an electromagnetic field.
2. Why is it important to find the principal axes of the electromagnetic stress tensor?
Finding the principal axes of the electromagnetic stress tensor allows us to determine the direction and magnitude of the stress and strain in an electromagnetic field. This information is crucial for understanding the behavior and effects of electromagnetic fields on materials and structures.
3. How is the principal axes of the electromagnetic stress tensor calculated?
The principal axes of the electromagnetic stress tensor are calculated through a process called diagonalization. This involves finding the eigenvalues and eigenvectors of the matrix, which represent the directions and magnitudes of the principal axes, respectively.
4. What factors can affect the principal axes of the electromagnetic stress tensor?
The principal axes of the electromagnetic stress tensor can be affected by the type and intensity of the electromagnetic field, the material properties of the medium, and the geometry of the structure in which the field is present.
5. How can knowledge of the principal axes of the electromagnetic stress tensor be applied in real-world situations?
Understanding the principal axes of the electromagnetic stress tensor is important in the design and analysis of devices that utilize or are exposed to electromagnetic fields, such as electronics, antennas, and medical imaging equipment. It can also be used to predict and mitigate potential damage or failure in structures and materials caused by electromagnetic stress.
