Finding pulley diameter with speed in rpm
In summary, the conversation discusses a pulley system with four pulleys, A, B, C, and D, attached to a single output axle. The speed and torque output can be changed by moving the drive belt between these pulleys. The question at hand is how to find the diameter of pulley C, given that it needs to run at a speed of 2,000 rpm and pulley A is already moving at 1,500 rpm. The solution involves using an equation that relates the diameter and rotational speed of two pulleys in order to solve for the unknown diameter of pulley C.
Tambourine Man
[/B]
In a pulley system, pulley A is moving at 1,500 rpm and has a diameter of 15 in. Three pulleys, B, C, and D, all of different sizes, are attached to a single output axle. Speed and torque output are changed within the system by moving the drive belt between pulleys B, C, and D.
A speed of 2,000 rpm is required when the drive belt is connected to pulley C. What is the diameter of pulley C?
The question is here, how do I find the diameter? I don't know the input or output speeds.
(not sure if this is right)
[/B]
You sure about that?...
... pulley A is moving at 1,500 rpm...
...A speed of 2,000 rpm is required...
There's no equality so that's not an equation.
You're looking for an equation that relates the diameter of a pair of pulleys with their rotational speed, check your notes and/or textbook. You know both RPM's and one diameter so can solve for the single unknown; the second pulleys diameter.
Related to Finding pulley diameter with speed in rpm
What is the formula for finding pulley diameter with speed in rpm?
The formula for finding pulley diameter with speed in rpm is: diameter = (speed * 60) / (pi * rpm).
Can this formula be used for any type of pulley?
Yes, this formula can be used for any type of pulley as long as the speed and rpm are measured in consistent units (e.g. feet per minute and revolutions per minute).
What are the units of measurement for the resulting diameter?
The units of measurement for the resulting diameter will be the same as the units used for speed and rpm (e.g. feet, meters, etc.).
Is there a specific value for pi that should be used in the formula?
Yes, the standard value for pi (π) should be used in the formula, which is approximately 3.14159.
Can this formula be used to find the pulley diameter in any system of measurement?
Yes, this formula can be used to find the pulley diameter in any system of measurement as long as the units are consistent and the value for pi is accurate.
  • Mechanical Engineering
