MHB Finding region of xy plane for which differential equation has a unique solution
find_the_fun
Determine a region of the xy-plane for which the given differential equation would have a unique solution whose graph passes through a point [math](x_0, y_0)[/math] in the region.
[math]x \frac{dy}{dx} = y[/math]
What does an xy-plane have to do with anything? I looked up the definition of unique solutions and here it is
Let R be a rectangular region in the xy-planed defined by a <=x<=b, c<=y<=d that contains the point [math](x_0, y_0)[/math] in its interior. If f(x,y) and [math]\frac{\partial{d} f}{\partial{d} y}[/math] are continuous on R then there exists some interval [math]I_0: (x_0-h, x_0+h), h>0[/math] contained in [a/b] and a unique function y(x) defined on [math]I_0[/math] that is a solution of the initial value problem.
That's a bit difficult to digest. How do I proceed?
In each of the regions $D\equiv x>0$ and $D'\equiv x<0$ the differential equation is equivalent to $y'=f(x,y)=\dfrac{y}{x},$ and in both regions, $f$ and $\dfrac{\partial f}{\partial y}=\dfrac{1}{x}$ are continuous, so and according to a well known theorem, $D$ and $D'$ are solutions to your question.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
