Finding relationship between Range and Launch height
In summary: Why must the relationship be linear to compare measured to predicted values? You could have some other functional form and still compare, couldn't you?
Sam 1998
I am currently trying to find a way to determine the relationship between launch height and range for a projectile launched at less than horizontal.
Would vary launch height to and measure range.
I need a directly proportional equation or at least a linear relationship.
In next part
[/B]
Sh = Vh*t
Sv = Vov*t + 1/2*a*t^2
Where the launch velocity components are:
Vv = v*sin(launch angle)
Vh = v*cos(Launch Angle)
Therefore,
Sh = v * cos(launch angle) * t so t = Sh/v*cos(launch angle)
Sv = v*sin(launch angle) * t + 1/2*a*t^2
Substituting time,
Sv = v*sin(launch angle) * (Sh/ v * cos(launch angle)) + 1/2 * a * (Sh/ v * cos(launch angle))^2
This is as far as I have got however I need to find a way to show the direct relationship between launch height and range. I am assuming now this isn't possible due to the quadratic, however can anyone think of a solution?
Can you solve for the zeros of a quadratic equation (in general)?
Yes but having it in a quadratic form won't give a linear relationship. Is there an alternative to my method that would yield a linear relationship between range and launch height?
Why would you expect to have the relationship be linear? I'm not saying that I KNOW it to be non-linear, but I would have started out with the assumption that it would NOT be, not that it would be.
For the purpose of the school report, we must have a linear relationship in the form y = mx +c, so that the m value can be compared to measured values to prove the accuracy of the data.
Well, maybe the relationship IS linear, I just would not have expected it to be.
Related to Finding relationship between Range and Launch height
1. How does increasing the launch height affect the range of a projectile?
As the launch height increases, the range of a projectile also increases. This is because the initial velocity of the projectile is greater, resulting in a longer flight time and therefore a longer distance traveled.
2. Is there a correlation between the range and launch height of a projectile?
Yes, there is a direct correlation between the range and launch height of a projectile. As the launch height increases, the range also increases, following a linear relationship.
3. What other factors besides launch height can affect the range of a projectile?
Other factors that can affect the range of a projectile include the initial velocity, angle of launch, air resistance, and the mass of the projectile.
4. Can the range of a projectile be calculated using a formula?
Yes, the range of a projectile can be calculated using the formula R = (v^2 * sin(2θ))/g, where R is the range, v is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity.
5. How can the relationship between range and launch height be applied in real-life situations?
The relationship between range and launch height can be applied in various real-life situations, such as in sports like baseball or javelin throwing, in military operations, and in understanding the trajectory of objects in space.
22K
