Finding Req - Understanding Professor's Solution
  • Thread starter zr95
In summary, the conversation discusses the process of solving a circuit problem involving series and parallel resistors. The professor's solution involves immediately adding two resistors together, while the student redraws the circuit to find the parallel connections. There is also a question about whether the resistors would still be in parallel if the circuit was not redrawn, and the importance of recognizing short-circuited nodes and using symmetry to simplify the circuit. The principle used to justify immediately adding resistors is that if there is no path between two points that does not pass through the resistors in question, then those resistors must be in series.
zr95
25
Series: Req = r1 + r2...
Parallel: 1/req = 1/r1 + 1/r2...
This is my professors solution for the problem and of course without any explanation it doesn't make sense to me. Under what principle can he justify immediately adding 10 + 8?
For my solution I redrew the circuit and did:
5||20 = 4
10+4 = 14
3 || 6 = 2
2+8 = 10
10+14 = 24
Another question: Had I not redrawn the circuit I still would've gotten 14 and 10 but I would've thought they would be in parallel with each other with the way its drawn out?
I understand redrawing it is the easiest way to make sure I have it correct but there won't be enough time unless I immediately recognize what it looks like.
Is there any path that you can draw between a and b (following circuit pathways of course) that does not pass through both the 10 and 8 Ohm resistors? If not, they must be in series between a and b.
The trick is to look at the nodes that are bridged by a short circuit. In this circuit nodes c and f are connected together via a wire. That means you are free to move all the connections at one of those nodes to the other node. Symmetry also helps here, as you can put nodes c and f together by "folding" the circuit along a line passing through d-a-b-e. Once you make that fold you've got your parallel resistor connections that you and your professor found, while the two series resistors are left at the fold.
Related to Finding Req - Understanding Professor's Solution
What is "Finding Req - Understanding Professor's Solution"?
"Finding Req - Understanding Professor's Solution" is a method used by scientists to analyze data and identify patterns or trends in order to make conclusions or predictions about a particular topic or problem.
Why is "Finding Req - Understanding Professor's Solution" important?
"Finding Req - Understanding Professor's Solution" is important because it allows scientists to make informed decisions and draw accurate conclusions based on data. It also helps to validate or refute hypotheses and can lead to new discoveries.
What are the steps involved in "Finding Req - Understanding Professor's Solution"?
The steps involved in "Finding Req - Understanding Professor's Solution" typically include identifying a research question, collecting data, organizing and analyzing the data, interpreting the results, and drawing conclusions or making predictions based on the findings.
What are some common challenges or limitations in "Finding Req - Understanding Professor's Solution"?
Some common challenges or limitations in "Finding Req - Understanding Professor's Solution" include biased data, small sample sizes, and confounding variables that may affect the results. It is important for scientists to carefully consider these factors and use appropriate methods to minimize their impact.
How does "Finding Req - Understanding Professor's Solution" contribute to the scientific community?
"Finding Req - Understanding Professor's Solution" contributes to the scientific community by providing a systematic and objective approach to understanding and explaining the world around us. It helps to advance knowledge and understanding in various fields and can lead to practical applications and solutions to real-world problems.
