Finding resultant electric field
In summary: So I guess it should be fine.In summary, we have two point charges, one at the origin and one 3cm in the +x direction, with values of -5.0nC and +3nC respectively. The electric fields E1 and E2 at point P, located at y=4cm, were calculated using unit vector notation and found to be -28125 V and 10800 V respectively. The resultant electric field E at P was then calculated using unit vector form and found to be approximately 20500 V, which is smaller than the sum of E1 and E2. This is due to the fact that the two charges have opposite charges and thus attract each other, decreasing the magnitude of the resultant
cwbullivant
60
Point charge q1 = -5.0nC is at the origin and point charge q2 = +3nC is 3cm in the +x direction. Point P is at y = 4cm. (a) Calculate the electric fields E1 and E2 at P due to charges q1 and q2, expressed in unit vector notation. (b) Use the results from the previous question to find the resultant electric field E at P, expressed in unit vector form.
$$ \vec{E} = \frac{1}{4\pi\epsilon_{0}} \frac{q}{r^{2}}\hat{r} $$
Simply plugging in the constants (q1 = -5 x 10^-9, q2 = 3 x 10^-9, r1 = .04, r2 = .05) gets the following values for E1 and E2:
|E1| = -28125 V
|E2| = 10800 V
Based on this, I expected the magnitude of the resultant electric field to be -17325 V.
Then, to solve using unit vectors, I drew the components from point P:
The vector E1 is raised 36.9 degrees west of north, which would give the components of E1 as follows:
E1 = <-10800sin(36.9), 10800cos(36.9)>
Since E2 is simply pointed down toward the origin, it has an angle of zero, leaving it as:
E2 = <0, -28125>
And adding the two up for the vector sum:
E = <-10800sin(36.9) + 0, 10800cos(36.9)-28125>
So far this seemed entirely correct. But when I checked the calculation by determining the magnitude of the sum, it came out to about 20,500 V. I figure I must be missing something obvious, but I can't quite figure out what it is.
Uhm, where is the point, P located in the x-direction? How did you calculate r1 and r2 with respect to that?
To me it seems like you need to do it component wise. So you need to seperate
$$ \hat{r} $$
into two components, x and y and give it for instance
$$ \hat{x} $$
and
$$ \hat{y} $$
for unit vectors. Are you unfamiliar with this kind of notation?
Now you have to calculate the electric field in the x and y direction seperately. Say you want to calculate the electric field E3 at a point at x=3 and y=5, you would then use the equation in the following manner:
$$ E3 = \frac{1}{4\pi \epsilon_0} \frac{q}{3\hat{x} + 5\hat{y}} $$
$$ \hat{r} $$
$$ \hat{x} $$
and
$$ \hat{y} $$
Sorry, P is located at 0 in the x direction. The distances were calculated by converting them to meters, and the distance from q2 to P was done by noting that the right triangle created by q1q2P is a Pythagorean triple (3,4,5, in this case).
1) check your E-field units!
2) you don't add the x-component to the y-component. keep the 6480 V/m (x) separate!
1) Noted. I forgot that Potential and Electric field have different units.
2) I didn't add the x-component to the y-component, as far as I can see. The sin(36.9) is associated with the x-component of E2 because the angle is measured from the y-axis (I think this might be why it looks like that).
E1 = 0(i) + 28125(-j)
E2 = 10800sin(36.9)(-i) + 10800cos(36.9)j
(I mixed up E1 and E2 in the original post, but the components were still the same)
For starters I would believe, you swapped the sine and cosine? So cosine should relate r to the x-direction, and sine would relate r to the y direction, though I doubt it changes much.
Also the way you "check" your result seems to be odd. When you add E1 and E2 you get a smaller magnitude for the resulting electric field. Does that make sense to you?
You have two charges of opposite charges, what would you usually expect happens to the electric field in such case? Would they attract or repel, and thus either increase or decrease at a point between them?
A drawing is always good for this.
Besides of that the math seems to be correct, and if I check it with the numbers you provided, I do get the same results in both ways that you did.
FAQ: Finding resultant electric field
1. What is a resultant electric field?
A resultant electric field is the overall electric field at a point in space, taking into account the contributions from all nearby charged objects or particles.
2. How do you find the resultant electric field?
To find the resultant electric field, you must first calculate the individual electric fields from each charged object or particle using Coulomb's law. Then, use vector addition to add these individual fields together to find the final resultant electric field.
3. What factors affect the magnitude and direction of the resultant electric field?
The magnitude and direction of the resultant electric field are affected by the distance between charged objects, the magnitude of their charges, and the orientation of their positions and charges relative to each other.
4. Can the resultant electric field be negative?
Yes, the resultant electric field can be negative. This means that the direction of the field is opposite to the direction of the force that would be experienced by a positive test charge placed in that field.
5. How is the resultant electric field different from the electric field at a single point?
The resultant electric field takes into account the contributions from all nearby charged objects or particles, while the electric field at a single point only represents the field from a single charged object or particle. Additionally, the magnitude and direction of the resultant electric field may be different from the electric field at a single point depending on the number and arrangement of charged objects or particles in the vicinity.
