Finding roots of a complex number
In summary: But...where does (0,-1) lie on the unit circle? There are many "angles" one can associate with that point (add $2\pi$ to anyone of them, and you get another one), but there is only the ONE point. So...pick an angle that works, and divide it by two. That's one of your square roots...what's the other one?I don't know. I'm just trying to help.
Drain Brain
144
I'm trying to solve this problem and got stuck.
Find the roots of $\sqrt{-j}$
converting $0-j$ into polar form
$r=\sqrt{0^2-1^2}=1$
$\theta=\tan^{-1}\left(\frac{-1}{0}\right)$ I got stuck on this part. please help.
Mathematics news on Phys.org
Have you not even thought to plot -j on an Argand Diagram? This would make finding the argument (angle) unbelievably easy...
I have not considered that.
I can see when I graph $0-j$ it is lying on y-axis donward making an angle of 270 deg.
Except that the angles are always measured in radians and the principal argument is measured in the domain $\displaystyle \begin{align*} \theta \in \left( -\pi, \pi \right) \end{align*}$.
You will also need to get a GENERAL angle (since the arguments are repeated every $\displaystyle \begin{align*} 2\pi \end{align*}$ units).
the principle angle should be $-\frac{\pi}{2}$ correct?
what do you mean by "general angle"?
Meaning that in general, the angle is of the form $\displaystyle \begin{align*} -\frac{\pi}{2} + 2\,\pi\,n \end{align*}$, where n is an integer.
What you are really doing is solving the complex quadratic:
$z^2 + j = 0$.
If we write:
$z = r(\cos\theta + j\sin\theta)$, we have:
$z^2 = r^2(\cos2\theta + j\sin2\theta) = 0 + j(-1)$.
It follows that $r = 1$, and that:
$\cos2\theta = 0$
$\sin2\theta = -1$.
Now there are an infinite number of $\theta$'s that would work, but we only need to find 2 that correspond to two different complex numbers.
$z^2 + j = 0$.
If we write:
$\cos2\theta = 0$
$\sin2\theta = -1$.
from your solution how do I find $\theta$?
I'm thinking of taking the inverse of
$\cos2\theta = 0$
$\sin2\theta = -1$.
is that correct?
$\cos2\theta = 0$
$\sin2\theta = -1$.
is that correct?
Well, the inverse trig functions on a calculator, let's say, would give you:
$\cos^{-1}(0) = \dfrac{\pi}{2}$
$\sin^{-1}(-1) = -\dfrac{\pi}{2}$
which doesn't give you a consistent answer. BE VERY CAREFUL WITH INVERSE TRIG FUNCTIONS. The sine and cosine functions are NOT one-to-one, they are PERIODIC.
FAQ: Finding roots of a complex number
What are complex numbers?
Complex numbers are numbers that have both a real and imaginary part. They are written in the form a + bi, where a is the real part and bi is the imaginary part. The imaginary unit i is equal to the square root of -1.
How do you find the roots of a complex number?
To find the roots of a complex number, you can use the formula z = √(r(cosθ + isinθ)), where r is the magnitude of the complex number and θ is the angle in the complex plane. Then, the n-th roots of z can be found by taking the n-th root of r and multiplying it by cos(θ/n) + isin(θ/n).
Can complex numbers have multiple roots?
Yes, complex numbers can have multiple roots. For example, the square root of 4 can be either 2 or -2. In general, a complex number can have n distinct n-th roots.
How do you represent complex numbers on a graph?
Complex numbers can be represented on a graph known as the complex plane. The real part of the complex number is plotted on the horizontal axis, while the imaginary part is plotted on the vertical axis. The complex number a + bi can be represented as the point (a,b) on the complex plane.
What are the applications of finding roots of complex numbers?
Finding roots of complex numbers has various applications in mathematics, engineering, and physics. Some examples include solving polynomial equations, analyzing electrical circuits, and understanding the behavior of waves. It is also used in computer graphics and cryptography.
