Finding $S_{2013}^2$ from a Given Sequence
  • MHB
  • Thread starter Albert1
  • Tags
    Sequence
In summary, $S_{2013}^2$ refers to the sum of the squares of the first 2013 terms in a given sequence. It is important in understanding the properties of a sequence and can be calculated by identifying the first 2013 terms, squaring them, and adding them together. $S_{2013}^2$ cannot be negative and is not applicable if the sequence has less than 2013 terms.
Albert1
1,221
a sequence ${a_n>0}$ for all n
given :$S_n - \dfrac{1}{a_n}=a_n-S_n$
find :$S_{2013}^2$
where :$S_n=a_1+a_2+-------+a_n$
Mathematics news on Phys.org
One can easily find the first terms in the series:
\[a_1=\sqrt{1}-\sqrt{0} \\ a_2 = \sqrt{2}-\sqrt{1} \\ a_3 = \sqrt{3}-\sqrt{2}\]
Suppose this system holds for the nth level (n > 3): $a_n = \sqrt{n}-\sqrt{n-1}$ and let´s find $a_{n+1}$:
\[2S_{n+1} = a_{n+1}+\frac{1}{a_{n+1}} \\\\ 2(\sqrt{n}+a_{n+1}) = a_{n+1}+\frac{1}{a_{n+1}} \\\\ a_{n+1}^2 + 2\sqrt{n}\cdot a_{n+1}-1 = 0 \\\\ a_{n+1} = \frac{1}{2}\left ( -2\sqrt{n}\; \pm \sqrt{4n+4} \right ) \\\\ a_{n+1} = \sqrt{n+1}-\sqrt{n}\]
By the principle of induction $a_n=\sqrt{n}-\sqrt{n-1}$ and $S_n=\sqrt{n}$ for $n = 1,2,3,..$
Thus $S_{2013}^2 = (\sqrt{2013})^2 = 2013$
very good solution :)
FAQ: Finding $S_{2013}^2$ from a Given Sequence
What is the meaning of $S_{2013}^2$ in the context of a given sequence?
$S_{2013}^2$ refers to the sum of the squares of the first 2013 terms in a given sequence. In other words, it is the sum of the squares of the first 2013 numbers in the sequence.
Why is it important to find $S_{2013}^2$ from a given sequence?
Finding $S_{2013}^2$ can provide valuable information about the behavior and properties of a given sequence. It can also be used in various mathematical calculations and applications.
What are the steps to finding $S_{2013}^2$ from a given sequence?
The steps to finding $S_{2013}^2$ from a given sequence may vary depending on the specific sequence. However, in general, it involves identifying the first 2013 terms in the sequence, squaring each term, and then adding them all together to get the final result.
Can $S_{2013}^2$ be negative?
No, $S_{2013}^2$ cannot be negative. Since it is the sum of squares, all terms in the sequence must be squared, resulting in only positive values. If the sequence contains negative numbers, their squares will still be positive when added together.
What if the given sequence has more or less than 2013 terms?
If the given sequence has more than 2013 terms, $S_{2013}^2$ can still be found by following the same process, but using the first 2013 terms. If the sequence has less than 2013 terms, $S_{2013}^2$ will not be applicable as it requires 2013 terms to be calculated.
