Finding shear and normal stress after rotation
In summary, shear stress is a measure of the force per unit area that acts parallel to a surface and is calculated by dividing the force applied by the area over which it acts. Normal stress, on the other hand, is a measure of the force per unit area that acts perpendicular to a surface. It is important to find both shear and normal stress after rotation in order to understand how the changes in stress distribution may affect the structural integrity of the object. The factors that can affect shear and normal stress after rotation include the shape and geometry of the object, applied forces, material properties, temperature, and external loads. Common methods for finding shear and normal stress after rotation include using equations derived from mechanics, finite element analysis, and experimental testing.
chetzread
801
http://ocw.nthu.edu.tw/ocw/upload/8/256/Chapter_7-98.pdf refer to page 3
in the 2nd, 3rd pictures, i have problem of finding σx'
why can't use the formula to find σs ?
it's given that σx' = ( σx+ σy)(0.5) + (0.5)( σx- σy)cos2θ + τxy(sin2θ)
= (100+60)(0.5) +(0.5))100-60)(cos60) +52(sin60)
=155
But, the author found σx = 111.6 using Mohr's circle method, why i can't use this method? did i miss out something?
Thank you for bringing up this question. It is important to understand the difference between the two methods you mentioned - using the formula and using Mohr's circle method - and when to use each one.
The formula you mentioned, σx' = ( σx+ σy)(0.5) + (0.5)( σx- σy)cos2θ + τxy(sin2θ), is derived from basic mechanics equations and can be used to calculate the stress on a given plane (in this case, the x' plane) using the stresses on the x and y planes and the angle θ. This method assumes that the material is isotropic (has the same properties in all directions) and that the stress state is known.
On the other hand, Mohr's circle method is a graphical method used for visualizing and analyzing stress states in 2D. It is based on the concept of principal stresses and can be used to determine the maximum and minimum stresses on a given plane, as well as the angle of the principal planes. This method can be used for both isotropic and anisotropic materials and does not require the stress state to be known beforehand.
In this case, the author likely used Mohr's circle method because it allows for a visual representation of the stress state and can provide more information than just the stress on the x' plane. It is possible that the author also used this method because the material may not be isotropic, as indicated by the presence of τxy in the formula.
In summary, both methods can be used to find the stress on a given plane, but they have different underlying assumptions and applications. I hope this explanation helps to clarify the differences between the two methods. If you have further questions, please do not hesitate to ask.
Related to Finding shear and normal stress after rotation
1. What is shear stress and how is it calculated?
Shear stress is a measure of the force per unit area that acts parallel to a surface. It is calculated by dividing the force applied by the area over which it acts. In the context of rotation, shear stress can be found by dividing the torque applied by the cross-sectional area of the object being rotated.
2. How is normal stress different from shear stress?
Normal stress, also known as axial stress, is a measure of the force per unit area that acts perpendicular to a surface. This is in contrast to shear stress, which acts parallel to a surface. In the context of rotation, normal stress can be found by dividing the applied force by the cross-sectional area of the object being rotated.
3. Why is it important to find shear and normal stress after rotation?
After rotation, the distribution of stress in an object may change, and it is important to understand how these changes may affect the structural integrity of the object. By finding shear and normal stress, engineers and scientists can determine if an object can withstand the applied forces and make necessary design modifications.
4. What factors can affect the shear and normal stress after rotation?
The shear and normal stress after rotation can be affected by various factors such as the shape and geometry of the object, the magnitude and direction of the applied forces, and the material properties of the object. Other factors, such as temperature and external loads, may also play a role.
5. What are some common methods for finding shear and normal stress after rotation?
Some common methods for finding shear and normal stress after rotation include using equations derived from the principles of mechanics, such as Mohr's circle or the stress transformation equations. Finite element analysis and experimental testing are also commonly used methods for determining stress distribution in a rotated object.
10K
