MHB Finding Side Lengths of Tangram Shapes
  • Thread starter Thread starter Deeds
    Shapes
The discussion focuses on determining the side lengths of various tangram shapes, specifically isosceles right triangles, a square, and a parallelogram, arranged to form a 1x1 unit square. The user has successfully calculated the dimensions of the large triangles but is uncertain about the next steps without making midpoint assumptions. There is a request for clarification on the mathematical reasoning behind the placement of certain points, particularly how JF lies on a diagonal of the square. The response explains that since JF is perpendicular to a known diagonal and passes through a vertex, it must be part of that diagonal. The conversation highlights the challenges of visualizing and mathematically proving relationships within the tangram configuration.
Deeds
Hello, I'm trying to find the lengths of the sides of all of the shapes in the below tangram. This is what is given:
• 2 large, and congruent, isosceles right triangles
• 1 medium isosceles right triangle
• 2 small, and congruent, isosceles right triangles
• 1 square
• 1 parallelogram
The pieces can be rearranged with no gaps or overlapping of shapes into a square with dimensions 1 unit by 1 unit (i.e., the entire area of the square is 1 unit^{2}) You cannot make midpoint assumptions.
I've figured out the lengths of the two large triangles. (1 for the hypotenuse and \sqrt{2}/2 for the other two legs). Without assuming midpoints, I'm not sure where to go next. Thanks.
Mathematics news on Phys.org
Hi,
I hope the following is understandable and helps.
johng said:
Hi,
Thank you so much for your help. Most of it I understand. I will sit with this later to see if I can get it to connect in my brain. :-) If not, I'll ask you more questions.
Again, thank you so much!
See also http://mathhelpboards.com/geometry-11/tangrams-11357.html?highlight=tangram.
johng said:
Hi,
I'm confused about how you know that JF lies on a diagonal of the large square. I can understand how AK does and I can visually and conceptually see how JF would, but how can I mathematically show that?
Sorry, this problem is so difficult for me. Thanks again.
You know that AK is a diagonal of the large square. You also know that JF is perpendicular to AK (because the angles at F are right angles). Since the diagonals of a square are perpendicular to each other, it follows that JF must be parallel to the other diagonal. But since it passes through the vertex J, it must actually be part of that diagonal.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
