Finding some quantities of particles moving relativistically
In summary: The momentum of the car in the first case is zero, but in the second case the momentum of the car and the momentum of the bump are both significant. The same is true for particles.
ForTheGreater
A 2.5 MeV photon is moving in positive x-direction and an electron in the opposite direction at a velocity of 0.99c. Calculate their common total energy, momentum and total rest mass.
Relativistic Equations
I have some concerns with the statement of the question. First of all how is it relevant that the particles are going in opposite direction?
Not sure how to go about calculating the momentum of a photon since it has no mass, and would it ever get a relativistic rest mass?
When asked about the rest mass of the electron, how is that not just the table value? It's the relativistic mass that would need calculating.So I would like some help with this early exercise to get me going in the right way to think about such a problem. All examples in the textbook has been about observing a moving inertial frame of reference and finding the relativistic variables. This is quite different. Especially since a photon always moves at the speed of light.
It will influence all three values you are supposed to calculate.
There is a simple formula relating the energy to the momentum.
No.
The problem asks about the total rest mass, which is the invariant mass of the electron+photon system.
Forget the concept of relativistic masses, it is not used any more in science.
Photons carry momentum p = E/c. In relativity, mass is not required for an object to carry momentum. The fundamental relationship between energy, momentum, and mass is ##E^2 = p^2 + m^2##.
You are being asked for the total combined energy and momentum and invariant mass of the system containing the photon and electron, this is not the same as asking for their individual properties.
How?
Calculate it and you'll see.
Here is an intuitive analogy: bumping into a car at a highway that moves in the same direction as you is different from a collision with a car moving at the same speed in the opposite direction.
Related to Finding some quantities of particles moving relativistically
1. What is relativistic motion?
Relativistic motion refers to the movement of objects at speeds close to the speed of light, where the effects of special relativity become significant. This includes phenomena such as time dilation and length contraction.
2. How do you find the quantity of particles moving relativistically?
The quantity of particles moving relativistically can be calculated using the relativistic mass formula: m = m0/(1-(v^2/c^2))^(1/2), where m0 is the rest mass of the particle, v is its velocity, and c is the speed of light.
3. What are the units used for relativistic quantities?
Relativistic quantities are typically measured in units of energy, such as electron-volts (eV) or joules (J), or in units of velocity, such as meters per second (m/s) or the speed of light (c).
4. How does relativistic motion affect time and space?
Special relativity states that as an object approaches the speed of light, time slows down and length contracts in the direction of motion. This means that time and space are not absolute, but are relative to the observer's frame of reference.
5. What is the significance of particles moving relativistically?
Particles moving relativistically have important implications in fields such as particle physics and astrophysics. They allow us to study the fundamental nature of matter and the universe, and can also be utilized in technologies such as particle accelerators and nuclear reactors.
