I_Try_Math
- 101
- 20
- Homework Statement
- Two identical billiard balls collide. The first one is initially traveling at ##(2.2m/s)\hat{i}−(0.4m/s)\hat{j} ## and the second one at ##−(1.4m/s)\hat{i}+(2.4m/s)\hat{j}##. Suppose they collide when the center of ball 1 is at the origin and the center of ball 2 is at the point (2R,0) where R is the radius of the balls. What is the final velocity of each ball?
- Relevant Equations
- ##p_i = p_f##
## KE_{i} = KE_{f} ##
## \vec{v_{1i}} = \langle 2.2, -0.4 \rangle ##
## \vec{v_{2i}} = \langle -1.4, 2.4 \rangle ##
Let ##\theta## and ##\phi## be the angles made by ##\vec{v_{1i}}## and ##\vec{v_{2i}}## with the x axis, respectively.
Let ##\theta'## and ##\phi'## be the angles made by ##\vec{v_{1f}}## and ##\vec{v_{2f}}## with the x axis, respectively.
## p_{ix} = p_{fx} ##
## mv_{1ix} + mv_{2ix} = mv_{1fx} + mv_{2fx} ##
## v_{1ix} + v_{2ix} = v_{1fx} + v_{2fx} ##
## 0.8 = v_{1f}\cos(\theta') + v_{2f}\cos(\phi') ##
## p_{iy} = p_{fy} ##
## v_{1iy} + v_{2iy} = v_{1fy} + v_{2fy} ##
## 2 = v_{1f}\sin(\theta') + v_{2f}\sin(\phi') ##
## \frac{1}{2}mv_{1i}^2 + \frac{1}{2}mv_{2i}^2 = \frac{1}{2}mv_{1f}^2 + \frac{1}{2}mv_{2f}^2 ##
## v_{1i}^2 + v_{2i}^2 = v_{1f}^2 + v_{2f}^2 ##
## 12.75 = v_{1f}^2 + v_{2f}^2 ##
If I understand correctly I should be able to solve it using the the three blue equations. The problem is everytime I try the algebra gets kind of unwieldy and complicated, making me think my work is wrong or there is a different approach to the problem which is conceptually simpler.
Am I on the right track with this problem solving strategy? If so is there is a trick to make the algebra easier? Perhaps a trig identity?
