Mmm_Pasta
- 285
- 30
A massless spring has unstretched length Lo = 0.45 m and spring constant k = 122.3 N/m. A block of mass m = 1.87 kg is attached to the spring, and a student stretches the spring to a length of L = 1.1 m. Then the student releases the block and it shoots upward. What is the speed of the block when it returns to the position Lo for the first time?
Use gravity = 9.81 m/s2.
KE=1/2mv2
GPE=mgh
EPE=1/2kx2
Using conservation of energy, I set the energies at points. EPE when the spring is stretched is equal to KE and GPE at Lo. I got 1/2kx2=mgh + 1/2mv2. I found x by doing 1.1 m - 0.45 m. Since I am trying to find v I did 1/2kx2 - mgh = 1/2mv2. Then I plugged in the variables. 1/2(122.3 N/m)(0.65 m)2 - 1.87 kg(9.81 m/s2)(0.65 m) = 1/2(1.87 kg)v2. Doing the math I got 25.835875 J - 11.924055 J = (0.935 kg)v2. Which is 13.91182 J/0.935 kg = v2. My answer turned out to be 3.86 m/s, which turned out to be wrong.
