physicsneedslabs
- 5
- Homework Statement
- Your lab instructor has asked you to measure a spring constant using a dynamic method-letting it oscillate-rather than a static method of stretching it. You and your lab partner suspend the spring from a hook, hang different masses on the lower end, and start them oscillating. One of you uses a meter stick to measure the amplitude, the other uses a stopwatch to time 10 oscillations. Your data are as follows:
[Mass(g)] {Amplitude(cm)} |Time(s)|
[100] {6.5} |7.8|
[150] {5.5} |9.8|
[200] {6.0} |10.9|
[250] {3.5} |12.4|
Use the best fit line of an appropriate graph to determine the spring constant.
- Relevant Equations
- T=(2(pi))((m/k)^(1/2)), Fnet=ma, Fg=mg, g=9.8m/s^2; Correct answer is 6.5N/m
I averaged the masses and times (which i took the time given and divided by 10 because in the problem it says you measure the time it takes to complete 10 oscillations) then plugged them directly into the T=(2(pi)((m/k)^1/2) and got the wrong answer. This is really confusing me because I don't really know how to start. And it was hard to format the chart so masses have [ ] around them, amplitudes have { } around them, and times have | | around them.
