Finding strength, pull, telsa (anything) of an electromagnet
In summary, the electromagnet has been built and it is being tested to see its strength. It is being compared to other magnets to see which one is the strongest. It is hoped that by understanding the strength of the magnet, other factors that might affect its performance can be determined.
Pharrahnox
106
I have built a new electromagnet, my second one so far, in an attempt to make it better. I am trying to find its strength, whether that be in tesla, holding force (kg) or whatever other units there are, just so I can compare it with other magnets.
What I have is a steel bolt wrapped with 1000+ turns of 26AWG copper wire. There are 8 AA batteries in series, giving about 12V, and a current of about 0.22A. The coil is approximately 7cm long, and has an outer diameter of approximately 1.2cm (I think the bolt is 3/8 of an inch), with 8 layers of wire.
Can someone please provide me with the formula(e) required to find what I am looking for.
If there are any other variables needed please let me know. Also, what are good alternatives for a bunch of AA batteries? I would like it to be portable - not connected to a powerpoint - and to have it more powerful, so more current from the batteries.
Thanks for any help.
I looked at the formulae on Wikipedia, but I'm not sure which one is applicable. I only contact an object with one pole of the magnet, the head of the bolt.
When it is talking about air gaps in the magnetic field path, is that talking about between the magnet, is it meaning the air gap between the magnet and the metal object? If so, then when the object is contacting it, the gap would be so close to zero that it wouldn't matter, would it?
What I am looking for is the strength, as in holding force, of my magnet, when contacting the end of the steel bolt, wrapped in the coil. And also, if anyone has any ideas for a good, yet small power source.
The lifting capacity of an electromagnet is measured in Newtons.
Here are a few factors that have an impact on the lifting capacity:
Surface conditions
Magnetic lines of force pass easily through iron, but not air. Therefore anything that creates space or an air gap (e.g. dirt, paper, moisture, burrs, rust or paint) between the magnet and the lifted object will have a negative impact on the lifting capacity of the magnet.
Material to be lifted
Steel with a high carbon content, such as St37, is nearly as good a conductor as iron. Alloys, however, contain non-magnetic materials that have a negative impact on the magnetic conductance. AISI304, for instance, is nearly as poor a conductor of lines of force as air.
Thickness of load to be lifted
The greater the number of lines of force that can ‘flow’ from the magnet through the load, the more effective the magnet field will be. If the load is thin, the material will become ‘saturated’ with lines of force, preventing some of the lines of force produced by the magnet from ‘flowing’ through the material.
Magnet contact surface on lifted load
If the entire magnet surface does not make contact with the load during lifting, the lifting capacity will be reduced.
You may get more information here: http://instruct.tri-c.edu/fgram/web/mdipole.htm
Thankyou for the response. I will attempt to wrap my head around what it is saying, I don't know how I'll go, probably badly.
I'll get back to you with how I go...
FAQ: Finding strength, pull, telsa (anything) of an electromagnet
1. How do I determine the strength of an electromagnet?
The strength of an electromagnet can be determined by measuring its magnetic field using a gaussmeter. The higher the magnetic field strength, the stronger the electromagnet.
2. What factors affect the strength of an electromagnet?
The strength of an electromagnet is affected by the number of turns in the wire coil, the amount of current flowing through the coil, and the type of core material used. Increasing any of these factors will result in a stronger electromagnet.
3. How can I increase the pull force of an electromagnet?
The pull force of an electromagnet can be increased by increasing the number of turns in the wire coil, increasing the current flowing through the coil, or using a stronger core material. Additionally, placing the electromagnet closer to the object it is attracting can also increase the pull force.
4. What is the difference between pull force and magnetic field strength in an electromagnet?
The pull force of an electromagnet refers to the force with which it can attract or hold onto an object. This force is dependent on the number of turns in the wire coil, the current flowing through the coil, and the type of core material used. On the other hand, magnetic field strength is a measure of the intensity of the magnetic field produced by the electromagnet and is dependent on the same factors as pull force.
5. How do I calculate the tesla value of an electromagnet?
The tesla value of an electromagnet can be calculated by dividing the magnetic field strength in gauss by 10,000. For example, if the magnetic field strength is 20,000 gauss, the tesla value would be 2 tesla. It is important to note that the tesla value is a measure of magnetic field strength and not pull force.
