Ryaners
- 50
- 2
Find the sum of the following series:
$$ \left( \frac 1 2 + \frac 1 4 \right) + \left( \frac 1 {2^2} + \frac 1 {4^2} \right) +~...~+ \left( \frac 1 {2^k} + \frac 1 {4^k} \right) +~...$$
$$ \sum_{n = 1}^{\infty} \left( u_k+v_k \right) = \sum_{n = 1}^{\infty} u_k + \sum_{n = 1}^{\infty} v_k $$
$$ \sum_{n = 1}^{\infty} cu_k = c \sum_{n = 1}^{\infty} u_k $$
Sum of a geometric series ## \sum_{n = 1}^{\infty} ar^k = \frac a {1-r} ##
The question referred back to the two relations I've put in the 'relevant equations' section - I assumed I'm meant to use the first one. So I split the sum into two sums as follows:
$$ \sum_{n = 1}^{\infty} \left( \frac 1 {2^k} + \frac 1 {4^k} \right) = \sum_{n = 1}^{\infty} \frac 1 {2^k} + \sum_{n = 1}^{\infty} \frac 1 {4^k} $$
For the left term, I got:
$$\sum_{n = 1}^{\infty} \frac 1 {2^k} = \sum_{n = 1}^{\infty} \left( \frac 1 2 \right)^k = \frac 1 {1- \frac 1 2} = 2$$
Similarly for the right term:
$$\sum_{n = 1}^{\infty} \frac 1 {4^k} = \sum_{n = 1}^{\infty} \left( \frac 1 4 \right)^k = \frac 1 {1- \frac 1 4} = \frac 4 3 $$
Then adding these together gives me ## 3 \frac 1 3 ##, which is... the wrong answer
![Red Face :redface: :redface:](https://www.physicsforums.com/styles/physicsforums/xenforo/smilies/oldschool/redface.gif)
I can see that ## \frac 1 {4^k} = \frac 1 {2^{2k}} ## - has that got something to do with the solution?
Edit: I should say that the answer in the back of the book is ## \frac 4 3 ## which makes me think that there must be a way that the first series is 'incorporated into' the second, but I can't quite get my head around that...!
Thanks in advance!
