MHB Finding surface area with volume
The discussion revolves around calculating the minimum surface area of a pop can with a volume of 350ml. The initial equation derived was incorrect, but the correct surface area formula is A_s = 2(πr^3 + 350)/r. Participants suggest using the first or second derivative tests to find the optimal radius, but one user indicates they haven't learned calculus yet. Instead, they are advised to use graphical methods or the fact that for a cylinder with a given volume, the minimum surface area occurs when the height equals the diameter. Understanding these concepts can help in determining the dimensions effectively.
ahmedb
Ok, so I did a test today for advance functions and there was a question: the volume of a pop can is 350ml, find the minimum surface area and determine the dimensions.
Where I got stuck:350=pi(r)^2*h
h=350/pi(r)^2SA= 2pi(r)^2+2pi(r)( h)
SA= 2pi(r)^2+2pi(r)(350/pi(r)^2)=(2(pi(r)^3+350))/(pi(r))I'm stuck here :S
Mathematics news on Phys.org
Hi MoneyKing, :)
You should get,
\[A_{s}=\frac{2(\pi r^3+350)}{r}\]
Use, the first derivative test or the second derivative test to find out the value of \(r\) which minimizes \(A_{s}\).
Kind Regards,
Sudharaka.
Sudharaka said:
Hi MoneyKing, :)
You should get,
Kind Regards,
Sudharaka.
Hey Sudharaka,
How did you get \[A_{s}=\frac{2(\pi r^3+350)}{r}\]
and I didn't learn how to do the first derivative test or the second, can you show me, or tell me where I can learn how to do that?
please and thanks
MoneyKing said:
Hey Sudharaka,
please and thanks
Hi MoneyKing, :)
You have made a mistake in the highlighted part in post #1.
\[350=\pi r^2 h\mbox{ and }A_{S}=2\pi r^2+2\pi r h\]
\[\Rightarrow A_{S}=2\pi r^2+2\pi r\left(\frac{350}{\pi r^2}\right)\]
\[\Rightarrow A_{S}=\frac{2(\pi r^3+350)}{r}\]
There are loads of resources on the internet that you can learn about the first and second derivative tests. Here are two videos that you will find useful.
First Derivative Test: Calculus: 3.2 - Extrema and the First-Derivative Test - YouTubeSecond Derivative Test: Calculus: Concavity and the Second-Derivative Test - YouTube
Kind Regards,
Sudharaka.
Sudharaka said:
Hi MoneyKing, :)
Kind Regards,
Sudharaka.
thanks I see my mistake, umm if possible can you show me how to do this question? I still didn't take calculus, I just started Advance Functions, just finished first chapter
I don't think you would gain much from seeing differential calculus applied to find the extrema. Since you have not had calculus yet, I suspect you are to use graphical means to approximate the value of r for which the surface area is minimized.
If you graph the function, your calculator may even have a feature which allows you to find the minimum.
edit: It is also possible you may have been given the fact that for a given volume, the cylinder with minimum surface area has its height equal to its diameter. This would allow you to find the dimensions directly.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
