Alfreds9
- 29
- 1
Hello,
I have a practical problem, I'd like to find the "best" spot to hear sounds in a valley (forgive me if "acoustic point" isn't an appropriate term, I just couldn't come up with anything better and scrolling an acoustics text didn't help), or at least a non-blind spot (one which instead focuses on a relatively limited sector), to listen to as many sounds as possible. I am not sure if this could/would coincide with an echoing point.
I know this probably doesn't have have a precise answer or integral formula since factors such as wind speed, air humidity, temperature, ground elevation microtopography and tree cover would act as infinite variables, however I'd at least see what you do think and which tips I should follow to avoid the "worst" hearing spots.
I have elevation data of 30m resolution and topographic ground measurements, I know the tree cover from aerial pictures.
I drew a really crude sketch which if forgiven for my lack of drawing skills, could somehow better explain if I should look for a shallow point, an elevated one on the side, a really elevated one on the side or an elevated one in the middle (sketched just 3 example points since I couldn't clearly show supposed elevation differencies among them).
Edit: I forgot to add that most sounds would probably be randomly scattered both horizontally and vertically within 10m from soil level, possibly more densely distributed around a fixed point in the valley and mostly in the lower parts of the valley, within half of Hmax (maximum mountains height).
I'd consider "best" a point in which I'd hear most of them at the same time (even if obviously at different intensities due to various distance among them and me).Thank you
Allison
Allison
