MHB Finding the Altitude at a Given Air Pressure
Atmospheric pressure decreases with altitude, and the pressure at sea level is 101.33 kPa when substituting 0 feet into the formula. To find the altitude where air pressure is 70 kPa, one suggested using logarithms, but this method may not be suitable for the current class level. Instead, trial and error was proposed as an alternative, with one participant claiming to have found an altitude corresponding to 10 kPa. The discussion emphasizes the need for a simpler approach to solving the problem without logarithmic calculations.
tardisblue
Atmospheric pressure decreases as altitude increases. The pressure can be approximated by the formula $$P(h) = 101.33(0.9639)^\frac{h}{1000}$$ where $$P$$ is pressure in kilopascals and $$h$$ is height in feet.
a) What is the pressure at sea level (0 feet)?
b) At what altitude will the air pressure be 70kPa?So, I kinda have an idea how to do this. For a), you just sub in 0 for h, right? And that gets you 101.33
For b), do you just do trial and error until you get it to equal 70 feet? Could someone show the process/if there's an easier way?
Thanks!
Mathematics news on Phys.org
For part b) you can use logarithms to solve for $h$. Let $P(h)=70$:
$$70=101.33(0.9639)^{\frac{h}{1000}}$$
Now, if you have an equation of the form:
$$a=b\cdot c^{\frac{x}{d}}$$
and you wish to solve for $x$, the first thing I would do is divide through by $b$:
$$\frac{a}{b}=c^{\frac{x}{d}}$$
Next, we may take the natural log of both sides:
$$\ln\left(\frac{a}{b}\right)=\ln\left(c^{\frac{x}{d}}\right)$$
On the right, we may use the log property $$\log_a\left(b^c\right)=c\cdot\log_a(b)$$ to write:
$$\ln\left(\frac{a}{b}\right)=\frac{x}{d}\ln(c)$$
Next divide through by $$\frac{\ln(c)}{d}$$:
$$\frac{d\ln\left(\frac{a}{b}\right)}{\ln(c)}=x$$
Can you apply this procedure to the given problem?
Thanks for replying!
We don't go over logarithms for this class (that's next year), so I don't think that my teacher would want us to solve it like that, since this is a question on a test review.
So, is there any other method of solving that, without logarithms? I got the answer $$10$$ kPa through trial and error. Is that correct? Thanks again! (:
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
