Finding the angle of an electron striking a plate
In summary, the electron is fired at 4.0 x 106 m/s horizontally between the parallel plates, deflecting downwards and striking the bottom plate. The electric field between the plates is 4.0 x 102 N/C. The separation of the plates is 2.0 cm. The electron's acceleration is 7.0 x 1013 m/s2 and its horizontal distance traveled is 9.5 m.
chef99
75
An electron is fired at 4.0 x 106 m/s horizontally between the parallel plates, as shown, starting at the negative plate. The electron deflects downwards and strikes the bottom plate. The magnitude of the electric field between the plates is 4.0 x 102 N/C. The separation of the plates is 2.0 cm.
a) Find the acceleration of the electron between the platesa) Find the horizontal distance traveled by the electron when it hits the plate
Fnet y = FE - Fg
ΔDy =v1y Δt + 1/2 a Δt2
ΔDx = v1x Δt
vf = vi + (a)(t)
a)
Let right and down be positive.
Fnet y = FE - Fgma = qε - 0a = qε / ma =https://www.physicsforums.com/file://localhost/Users/jefferyhewitt/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image002.png (1.6 x10-19C)(4.0 x102N/C) / (9.11 x10-31kg)a = 7.03 x1013m/s2 [down]The acceleration of the electron is 7.0 x1013m/s2 [down].
b)
In order to calculate the distance traveled, the value of time (https://www.physicsforums.com/file://localhost/Users/jefferyhewitt/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image001.pngt) must be determined.https://www.physicsforums.com/file://localhost/Users/jefferyhewitt/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image002.pngΔDy =v1y Δt + 1/2 a Δt20.02m = 0 Δt +https://www.physicsforums.com/file://localhost/Users/jefferyhewitt/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image007.png1/2 (7.03 x1012) ΔtΔt = √(0.02m)(2) / (7.03 x 1013)Δt = 2.38 x10-8 sNow the value of time can be used to determine the horizontal distance traveled by the electron:
ΔDx = v1x Δt
ΔDx = (4.0 x106m/s)(2.38 x10-8s)
ΔDx = 9.5m
The horizontal distance traveled by the electron is 9.5m.c)
vf = vi + (a) (t)vf = (4.0 x106m/s)(7.03 x1013m/s)(2.38 x10-8s)vf = 6.69 x1012 m/sThe velocity of the electron as it strikes the plate is 6.7 x1012 m/s [ ].I think this is all right but, the one thing I don't know how to do but I think I have to determine the angle at which the electron strikes the plate. If anyone has suggestions I would greatly appreciate it.
ΔDx = 9.5m
vf = vi + (a) (t)
Check those two steps.
Thanks for pointing that out.
So
ΔDx = 0.0952
ΔDx = 9.5 x10-2m
and
vf = vi + (a) (t)
vf = 5673140
vf = 5.7 x106m/s
Also for c) do I have to determine the angle the electron strikes that plate or not?
chef99 said:
vf = vi + (a) (t)
this is still not right. You need to distinguish between directions. The initial velocity is at right angles to the acceleration.
Also, you did not post the question for part c. If it asks for a velocity then the answer should consist of a speed and a direction.
Related to Finding the angle of an electron striking a plate
What is the purpose of finding the angle of an electron striking a plate?
The angle of an electron striking a plate is an important measurement in understanding the behavior of electrons and their interactions with matter. It can provide valuable information about the energy, velocity, and direction of the electron, which can be used in various scientific fields such as physics, chemistry, and materials science.
How is the angle of an electron striking a plate measured?
The angle of an electron striking a plate can be measured using specialized equipment such as an electron diffraction device or an electron microscope. These instruments use principles of diffraction and imaging to determine the angle at which the electron strikes the plate.
What factors can affect the angle of an electron striking a plate?
There are several factors that can affect the angle of an electron striking a plate, including the initial velocity of the electron, the electric and magnetic fields present, and the properties of the material the electron is passing through. Additionally, the angle can be influenced by the shape and orientation of the plate itself.
Why is it important to accurately measure the angle of an electron striking a plate?
Accurately measuring the angle of an electron striking a plate is crucial for understanding the physical properties of the material being studied. It can also provide insights into the electronic structure and behavior of the material, which can have applications in fields such as materials engineering and nanotechnology.
What are some real-world applications of finding the angle of an electron striking a plate?
The measurement of the angle of an electron striking a plate has many practical applications, such as in the development of new materials with specific properties, the study of the structure of crystals and molecules, and in the design of electronic devices. It is also used in medical imaging techniques, such as electron microscopy, to visualize and analyze biological samples at a microscopic level.
19K
