Finding the angle of refraction
In summary: It's the best way to remember Snell's law because it works in all cases.In summary, the refractive index of diamond is 2.42 and the angle of incidence is 20 degrees. Using Snell's law, we can find the angle of refraction by taking the ratio of the sines of the angles in air and diamond, which is equal to the ratio of the refractive indices. Therefore, the angle of refraction is approximately 55.9 degrees.
RabbitWho
153
The refractive index of diamond is 2.42. A ray of light passing from the inside of a diamond into air makes an angle of incidence of 20 degrees. Find the angle of refraction.
n = refractive index
aNd = 2.42 (my book said the speed of light in a vacuum and in air are close enough to treat them as the same for our purposes)
dNa = 1/aNd
Sin i / Sin r = dNa
i = 20 degrees
0.413 = dNa
Sin 20 degrees = 0.3420
0.3420 / sin r = 0.413
therefore 0.3420 x 0.413 = sin r
sin r = 0.142
arc sin of 0.142 = 8.159 degrees
This is wrong, the answer should be 55.9 degrees..
Where did I go wrong?
Did I go wrong in my maths or in my use of the formula?
If someone could point me in the right direction that would be wonderful.
I think you los track of the refractive index ration and which to use where.
Instead use Snell's law as she is writ:
##\qquad n_1\sin\theta_1 = n_2\sin\theta_2##
... that way you can keep track.
Since the ray passes from the diamond into the air, which way will it bend (towards the normal or away from the normal)?
Likes RabbitWho
Why is this correct?
Start with ## n \sin \theta_i = \sin \theta_r ## and solve for ## \sin \theta_r ##.
Likes RabbitWho
That formula isn't taught in my book. I saw them explain it on Kahn Academy but I don't really understand it. I think it is just another way to express the same thing. I have to stick with the formula given for my exam. If I use any formula which is not on the syllabus there is a good chance I will be marked wrong, depending on who corrects my test. These are the formula:
Snell's law: n = sin i / sin r
xny = 1 / ynx
It will be bent away from the normal.
Why isn't it correct? The formula says sin i over sin r = dNa
So I have to multiply sin i by dNa to get sin r, right? Is my algebra wrong again?
OK, we will go by the formula that you are familiar with. I understand sin i is the sine of the angle of incidence and that sin r is the sine of the angle of refraction. Please explain what dNa stands for because I am unfamiliar with the notation.
Likes RabbitWho
Sorry about that!
I should have realized it wouldn't be clear.
we are using n for refractive index as well, but
aNd (and)
d stands for diamond and a stands for air, so aNd is the refractive index of light traveling from air into a diamond and dNa is the refractive index of light traveling from a diamond into air.
And, as the problem states, the refractive index of diamond is 2.42, which one do you think is given, dna or and?
Likes RabbitWho
it has to be and, doesn't it? Because all it says is "the refractive index", and the normal one to give is light traveling from air (or a vacuum) into the medium.
OK. Then, if light goes from air to diamond, Snell's law is
$$ \frac{sin \theta_{air}}{sin \theta_{diamond}} = {_an_d} $$
Right?
And when light goes from diamond into air,
$$ \frac{sin \theta_{diamond}}{sin \theta_{air}} = {_dn_a} $$
Right?
Can you solve for what you need? Note that these two equations say that it doesn't matter what is "incident" and what is "refracted". When you send light back where it came from, it will retrace its path. Also note that I used subscripts "diamond" and "air" instead of "i" and "r" to avoid confusion of what's what. I recommend you do the same if you are to use the form of Snell's law that was given to you. The rule is this "The subscript of the sine in the numerator matches the first subscript of n and the subscript of the sine in the denominator matches the second subscript of n."
Likes RabbitWho
Ah! Thank you, that was a silly mistake. Let me see if I can do it now
0.413 = dNa
sin r [sin theta diamond] / 0.3420 = 0.413
I think I am still going wrong somewhere because I can't see how to get 55.9 degrees out of what I have o_O Sorry about this
RabbitWho said:
0.413 = dNa
OK
OK
Use the two OK'ed numbers above and forget the others. Start with ## \frac{\sin \theta_{diamond}}{ \sin \theta_{air}}={_dn_a} ##
Which one of the quantities in the equation are you looking for and how can you find it?
Wow - no wonder you are confused. So besides what kuruman is telling you ...
If the speed of light in the medium is v, and the speed of light in vacuum is c, then, by definition, the refractive index for the material is n=c/v
Snells law is for light passing through an interface between two arbitrary transparent materials.
I wanted to point this out because it will help you later when you talk to people outside your particular course.
Refractive index for air is usually treated as 1 ... so for light passing from air to a material, ##\sin\theta_i = n\sin\theta r## and for light passing from the material to the air, ##n\sin\theta_i = \sin\theta_r## ... these are mathematically the same equation.
So the ratio ##\sin\theta_i/\sin\theta_r## is 1/n, if light goes from air to medium, and n if the light goes from medium to air.
The genaral Snells law is better because you only have one equation to get straight.
The maths does not care which direction the light travels, so there's one thing you don't need to worry about, and those mNa and aNm things take care of themselves so there's another two things not to worry about. The downside is that you need to be able to do algebra.
I'm pretty bad at memorizing stuff, so I always feel it is better to reduce the amount of memorization needed to do anything.
I'm going to let kuruman help you out here though... you don't need two people talking at you.
Related to Finding the angle of refraction
1. What is the angle of refraction?
The angle of refraction is the angle between the refracted ray and the normal line at the point of refraction.
2. How is the angle of refraction calculated?
The angle of refraction is calculated using Snell's law, which states that the ratio of the sine of the angle of incidence to the sine of the angle of refraction is equal to the ratio of the refractive indices of the two media.
3. What factors affect the angle of refraction?
The angle of refraction is affected by the angle of incidence, the refractive indices of the two media, and the speed of light in each medium.
4. Why is the angle of refraction important?
The angle of refraction is important because it determines how light rays will be bent when passing through different media, which is essential for understanding the behavior of light in various optical systems.
5. How does the angle of refraction relate to the angle of incidence?
The angle of refraction and the angle of incidence are related by Snell's law, which shows that as the angle of incidence increases, the angle of refraction also increases.
