Finding the Area bounded by the curve
In summary: Since the second integral is zero, the first integral is also zero, and the equation becomes:\int_{-a}^a f(x)\,dx=-2\int_0^a f(x)\,dx=0
shamieh
539
Find the area bounded by the curve \(\displaystyle x = 16 - y^4\) and the y axis.
I need someone to check my work.
so I know this is a upside down parabola so I find the two x coordinates which are
\(\displaystyle 16 - y^4 = 0\)
\(\displaystyle y^4 = 16\)
\(\displaystyle y^2 = +- \sqrt{4}\)
\(\displaystyle y = +- 2\)
so I know
\(\displaystyle \int^2_{-2} 16 - y^4 dy\)
Take antiderivative
\(\displaystyle 16y - \frac{1}{5}y^5\) | -2 to 2
so \(\displaystyle (2) = 32 - \frac{32}{5} = \frac{160}{5}\)
then \(\displaystyle (-2) = -32 - (\frac{-32}{5}) = -32 + \frac{32}{5} = \frac{-160}{5} + \frac{32}{5} = \frac{-128}{5}\)
SO finally
\(\displaystyle
[\frac{160}{5}] - [\frac{-128}{5}] = \frac{288}{5}\)
This is not a parabola. It is like a parabola that intersects the y-axis at \(\displaystyle y=\pm 2\) so it is open to the left. I suggest you revise your calculations.
I would use the even-function rule to state:
\(\displaystyle A=2\int_0^2 16-y^4\,dy=\frac{2}{5}\left[80y-y^5 \right]_0^2=?\)
Recalculated answer below if someone has a chance to check.
recalculated and got \(\displaystyle \frac{256}{5}\) . Is that correct?
- - - Updated - - -
Yea this rule is so much easier!
- - - Updated - - -
Mark, know anywhere where I can find a good definition of the even function rule, so I can see how and when I can apply it etc. I googled it but couldn't find this one.
Like how would I use this rule if i had \(\displaystyle 5 - x^2 \)?
- - - Updated - - -
- - - Updated - - -
Yes, your result of \(\displaystyle A=\frac{256}{5}\) is correct.
An even function is symmetric about the $y$-axis, i.e., \(\displaystyle f(-x)=f(x)\). If your limits of integration are also symmetric about the $y$-axis, then you may apply the even function rule.
Observe that:
\(\displaystyle \int_{-a}^a f(x)\,dx=\int_{-a}^0 f(x)\,dx+\int_0^a f(x)\,dx\)
Now, in the first integral, if we replace $x$ with $-x$, we have:
\(\displaystyle \int_{-a}^a f(x)\,dx=\int_{a}^0 f(-x)\,-dx+\int_0^a f(x)\,dx\)
Bringing the negative in front of the differential out front and using \(\displaystyle f(-x)=f(x)\), we have:
\(\displaystyle \int_{-a}^a f(x)\,dx=-\int_{a}^0 f(x)\,-dx+\int_0^a f(x)\,dx\)
Applying the FTOC, we obtain:
\(\displaystyle \int_{-a}^a f(x)\,dx=-\left(F(0)-F(a) \right)+F(a)-F(0)=2F(a)=2\int_0^a f(x)\,dx\)
Observe that:
\(\displaystyle \int_{-a}^a f(x)\,dx=-\int_{a}^0 f(x)\,dx+\int_0^a f(x)\,dx=\int_{0}^a f(x)\,dx+\int_0^a f(x)\,dx=2\int^a_0 f(x)\, dx \)
FAQ: Finding the Area bounded by the curve
What is the definition of "area bounded by the curve"?
The area bounded by the curve refers to the region enclosed by a curve on a graph. This area is typically calculated by finding the definite integral of the function that represents the curve.
How do I find the area bounded by a curve on a graph?
To find the area bounded by a curve on a graph, you must first determine the limits of integration, which are the x-values at which the curve starts and ends. Then, you can use the definite integral to calculate the area under the curve between these limits.
What is the difference between finding the area bounded by a curve and finding the area under a curve?
The area bounded by a curve refers to the specific region enclosed by a curve on a graph, while the area under a curve refers to the total area between the curve and the x-axis. The area bounded by a curve is typically calculated using the definite integral, while the area under a curve can be calculated using both the definite and indefinite integral.
Can the area bounded by a curve be negative?
No, the area bounded by a curve cannot be negative. This is because the definite integral, which is used to calculate the area, only produces positive values. If the curve dips below the x-axis, the area below the x-axis is considered negative and is subtracted from the positive area above the x-axis to yield a net positive value.
Why is finding the area bounded by a curve important in science?
Finding the area bounded by a curve is important in science because it allows us to calculate important quantities such as displacement, velocity, and acceleration. These quantities play a crucial role in understanding the behavior of physical phenomena and can help us make predictions and draw conclusions about the world around us.
