Finding the area inside of a loop
  • MHB
  • Thread starter shamieh
  • Tags
    Area Loop
In summary, to find the area inside one loop of a four leafed rose r = cos(2\theta), we can use the formula A = \int ^{\beta}_{\alpha} \frac{1}{2} [f(\theta)]^2 d\theta where \alpha and \beta are the values of \theta at which cos(2\theta) = 0. By solving for these values, we can find the integral to be \frac{\pi}{8}.
shamieh
539
I know this is relatively easy but I'm just confused on the process...
Find the area inside one loop of a four leafed rose \(\displaystyle r = cos(2\theta)\).
I know that the formula is \(\displaystyle A = \int ^{\beta}_{\alpha} \frac{1}{2} [f(\theta)]^2\) right?
I'm just not sure what to plug in or solve for.
So would the first step be to solve for \(\displaystyle \theta\)?
So:
\(\displaystyle cos^{-1}(r) = cos^{-1}(cos(2\theta))\)
\(\displaystyle = cos^{-1}(r) = 2\theta\)
then \(\displaystyle \theta = \frac{cos^{-1}(r)}{2}\) ? But how does that help me?
I know that the formula is \(\displaystyle A = \int ^{\beta}_{\alpha} \frac{1}{2} [f(\theta)]^2\color{red}{d\theta}\) right? Dont't forget the $\color{red}{d\theta}$!
It will help to have an idea of what the graph looks like.
[graph]lfg70xit5x[/graph] (click on it for an enlargement).
The reason it has loops is that there are some values of $\theta$ for which $r=0.$ Start by finding those values. That will tell you what to take for $\alpha$ and $\beta$.
I think I understand it now, can you verify if I have done this correctly?
So:
I don't know what \(\displaystyle cos(2\theta)\) is, but I do know what \(\displaystyle cos(\theta) = 0\)
Finding everywhere that \(\displaystyle cos = 0, \)
I found that \(\displaystyle cos = 0 @ \frac{\pi}{2}\) and \(\displaystyle cos\) is \(\displaystyle 0 @ \frac{3\pi}{2}\)
But I need \(\displaystyle cos(2\theta)\)
\(\displaystyle \therefore\) I can say: \(\displaystyle 2\theta = \frac{\pi}{2} = \frac{\pi}{4} \)
similarly \(\displaystyle 2\theta = \frac{3\pi}{2} = \frac{3\pi}{4}\)
Thus my integral is \(\displaystyle \frac{1}{2} \int^{\frac{3\pi}{4}}_{\frac{\pi}{4}} cos^2(2\theta) \, d\theta\) and after skipping a few steps of taking the A.D. I obtained : \(\displaystyle \frac{\pi}{8}\)
So:
\(\displaystyle \therefore\) I can say: \(\displaystyle \color{red}{2\theta = \frac{\pi}{2} = \frac{\pi}{4}} \)
similarly \(\displaystyle \color{red}{2\theta = \frac{3\pi}{2} = \frac{3\pi}{4}}\)
Your answer $\frac\pi8$ is correct. But your writing still shows some very bad habits. You can NOT say things like $\frac{\pi}{2} = \frac{\pi}{4}$ because it is blatantly untrue. You should only use the equals sign "=" to connect things that are equal to each other. What you should have written there is something like "$2\theta = \frac{\pi}{2}$ and therefore $\theta = \frac{\pi}{4}$".
Thanks for the help. Found another way to solve this.
Setting \(\displaystyle 2\theta = \frac{\pi}{2}\)
Since we only need the first point at which \(\displaystyle \cos(\theta) = 0 \)
we can then find \(\displaystyle \theta = \frac{\pi}{4}\)
\(\displaystyle \therefore\) 2 [ \(\displaystyle \int ^{\frac{\pi}{4}}_0 \frac{1}{2} [r]^2 d\theta \) ] \(\displaystyle = \frac{\pi}{8}\)
FAQ: Finding the area inside of a loop
What is the formula for finding the area inside of a loop?
The formula for finding the area inside of a loop is A = πr2 - (r2/2)(θ - sinθ), where r is the radius of the loop and θ is the angle between the two points where the loop crosses the x-axis.
How do you determine the radius of a loop?
The radius of a loop can be determined by measuring the distance from the center point to any point on the loop or by using the Pythagorean theorem (a2 + b2 = c2) if the loop is a perfect circle.
Can you find the area inside of a loop if it is not a perfect circle?
Yes, the formula for finding the area inside of a loop can be used for any shape of loop as long as the radius and θ are known.
Is it possible for the area inside of a loop to be negative?
No, the area inside of a loop cannot be negative as it is a measure of the space enclosed by the loop and negative area does not have a physical meaning.
How is the angle θ determined when finding the area inside of a loop?
The angle θ is determined by finding the x-intercepts of the loop where it crosses the x-axis. The angle can then be calculated using trigonometric functions such as sine or cosine.
