Finding the area of a triangle formed by 3 points in the plane
In summary, the area of a triangle formed by 3 points in the plane can be found by taking the absolute value of the determinant of the distances between the points and the line through the points.
MarkFL
MHB
13,288
Suppose we have 3 points in the plane given by:
$\displaystyle (x_1,y_1),\,(x_2,y_2),\,(x_3,y_3)$
and we wish to find the area of the triangle whose vertices are at these points.
We may let the base b of the triangle be the line segment between the first two points, and the altitude h of the triangle will be the perpendicular distance from the third point to the base.
Let's begin with the familiar formula for the area A of a triangle:
$\displaystyle A=\frac{1}{2}bh$
Now, using the distance formula, we find:
$\displaystyle b=\sqrt{(x_2-x_1)^2+(y_2-x_y)^2}$
The line through the first two points, using the point-slope formula is:
$\displaystyle y-y_1=\frac{y_2-y_1}{x_2-x_1}(x-x_1)$
Arranging this in slope-intercept form, we find:
$\displaystyle y=\frac{y_2-y_1}{x_2-x_1}x-\frac{x_1y_2-y_1x_2}{x_2-x_1}$
Now, using the formula for the distance between a point and a line, we find:
$\displaystyle h=\frac{\left|\frac{y_2-y_1}{x_2-x_1}x_3-\frac{x_1y_2-y_1x_2}{x_2-x_1}-y_3 \right|}{\sqrt{\left(\frac{y_2-y_1}{x_2-x_1} \right)^2+1}}$
$\displaystyle h=\frac{\left|(y_2-y_1)x_3-(x_1y_2-y_1x_2)-y_3(x_2-x_1) \right|}{\sqrt{(x_2-x_1)^2+(y_2-x_y)^2}}$
$\displaystyle h=\frac{\left|(x_3-x_1)(y_2-y_1)-(x_2-x_1)(y_3-y_1) \right|}{\sqrt{(x_2-x_1)^2+(y_2-x_y)^2}}$
And so we have:
$\displaystyle A=\frac{1}{2}\left|(x_3-x_1)(y_2-y_1)-(x_2-x_1)(y_3-y_1) \right|$
Comments and questions should be posted here:
http://mathhelpboards.com/commentary-threads-53/commentary-finding-area-triangle-formed-3-points-plane-4217.html
Moderator edit: This topic is for commentary pertaining to the tutorial:
http://mathhelpboards.com/math-notes-49/finding-area-triangle-formed-3-points-plane-2954.html
Hello, MarkFL!
Sorry, your formula doesn't work.
Try it for: $(0,0), (6,0), (0,4).$
The area should be $12.$The formula that I saw derived years ago:
. . $A \;=\;\dfrac{1}{2}\begin{vmatrix}1&1&1 \\ x_1 & x_2 & x_3 \\ y_1 & y_2 & y_3 \end{vmatrix}$
where we take the absolute value of the determinant.
Re: Finding the area of a triangle formed by 3 points in the plane
Thanks for catching my error, which I have corrected above...I should have followed my notes more carefully! (Smirk)
FAQ: Finding the area of a triangle formed by 3 points in the plane
What is the formula for finding the area of a triangle using 3 points?
The formula for finding the area of a triangle using 3 points in the plane is called the Heron's formula. It is given by:
A = √(s(s-a)(s-b)(s-c))
where s is the semiperimeter of the triangle, and a, b, and c are the lengths of the three sides.
Can the area of a triangle formed by 3 points in the plane be negative?
No, the area of a triangle can never be negative. It is always a positive value, as it represents the space enclosed by the triangle.
Can the 3 points used to find the area of a triangle be collinear?
No, the 3 points used to find the area of a triangle must not be collinear. This means that they should not lie on the same line. If they are collinear, the area of the triangle formed by them would be zero.
What happens if the 3 points used to find the area of a triangle are not in the same plane?
The area of a triangle can only be found if the 3 points are in the same plane. If they are not, then it is not possible to determine the area of the triangle using those points alone.
Is it possible to find the area of a triangle if one of the points is the origin (0,0)?
Yes, it is possible to find the area of a triangle if one of the points is the origin (0,0). However, the formula used for this scenario would be different, as the distance between the origin and the other two points must be considered.
