Finding the Capacitance of a Conducting disc
In summary, the potential at any point on the disc can be calculated directly from the given charge density. The potential is V = \frac{1}{4 \pi \epsilon_0} \int_∞^s \int_0^{2 \pi} \frac{A}{\sqrt{R^2-s^2}} \frac{1}{\sqrt{(s-s')^2}} s dφds.
RJLiberator
63
Consider a disc (negligible thickness) of radius R with its center at the origin. Assume that the disc has a radially symmetric surface charge density given by ##σ(s) = \frac{A}{\sqrt{R^2-s^2}}## at a distance s from the origin, where A is some constant. You can take it for granted that this charge density leads to a potential that is constant everywhere on the surface of the disc, and hence, is suitable for describing the electrostatics of a conducting disc, and hence, find the capacitance of a conducting disc of radius R.
[Hint: In principle, the potential at any position on the disc can be calculated directly from the given charge density. Write down that expression for a general point which is at a distance r from the center. Note that since the charge distribution is cylindrically symmetric, so will V(r), which means you can place r along the x-axis in the (s, φ) polar coordinate system. You will realize that the integrations that you need to do are not trivial (do not attempt to perform the integrations for a general r, as their solutions involve elliptic functions). However, since you are given that the potential is constant anywhere on the disc, i.e. it is independent of r, it suffices to find the potential due to the given charge density at a special point on the disc, where the integrations are very easy to perform. This will allow you to relate the constant A to the potential V. Then you can find the total charge Q and relate Q and V to each other.
C = Q/V
##V = \frac{1}{4 \pi \epsilon_0} \int \frac{ \rho}{r}d \tau##
The Polar coordinate idea is killing me, I think.
But, we know what the charge distribution is, that's good.
The hint tells me to place r on the x axis... this means that in the integrations, ##r = \sqrt{s-s'}## for the distance between some point s and r?
Now, I think the idea from the hint is in the following set up:
[tex] V = \frac{1}{4 \pi \epsilon_0} \int_∞^s \int_0^{2 \pi} \frac{A}{\sqrt{R^2-s^2}} \frac{1}{\sqrt{(s-s')^2}} s dφds[/tex]
To let s' be some number that makes the integration simple compared to impossible to integrate regularly.
As far as the dφ integration goes, we simply get a 2pi out of it.
Am I setting this up correctly?
To get the potential via an integral you need the electric field strength. Where do you have this expression?
Likes RJLiberator
Hi, thank you for the reply to my question.
I'm not sure I follow. Why would I need the electric field to get potential? The equation in the "relevant equations" part of this topic does not involve E. I have the charge density (given) from the problem. I would just need script r. I believe my problem here is in the script r, and I think it now needs to be understood with the law of cosines.
something like: ##\sqrt{s^2+s'^2-2ss'}##.
Ah, I misunderstood what you wanted to integrate. If you integrate over the charge density, why do you integrate from ##\infty## to s?
In addition, it is confusing to use s both as integration variable and integration bound.
You'll need something like the square root in your last post, yes.
Likes RJLiberator
Related to Finding the Capacitance of a Conducting disc
What is capacitance?
Capacitance is the ability of a conductor to store electrical charge. It is measured in Farads (F) and is defined as the ratio of the stored charge to the applied voltage.
Why is finding the capacitance of a conducting disc important?
Finding the capacitance of a conducting disc is important because it allows us to understand how much charge can be stored on the disc and how it will behave in an electrical circuit. This information is crucial in designing and analyzing electronic devices.
How can the capacitance of a conducting disc be calculated?
The capacitance of a conducting disc can be calculated using the formula C = (2πεrL)/ln(b/a), where C is the capacitance, εr is the relative permittivity of the material between the disc and its surroundings, L is the thickness of the disc, b is the outer radius, and a is the inner radius.
What factors affect the capacitance of a conducting disc?
The capacitance of a conducting disc is affected by the distance between the disc and its surroundings, the thickness and size of the disc, and the relative permittivity of the material between the disc and its surroundings. It is also affected by the type of material used for the disc, as different materials have different levels of conductivity.
How can the capacitance of a conducting disc be measured experimentally?
The capacitance of a conducting disc can be measured experimentally using a capacitance meter, which measures the amount of charge stored on the disc for a given voltage. Another method is to use a known capacitor in series with the disc and measure the total capacitance. The difference between the two measurements is the capacitance of the disc.
