Finding the capcitance of this capacitator
  • Thread starter Dell
Why isn't this correct?If you do that and then take the reciprocal of what you have, you will get the "correct" answer. The mistake you made was in taking the reciprocal first. There's no reason to think that the reciprocal of the sum of reciprocals should be equal to the sum of reciprocals of the reciprocals. The reciprocal of the sum of reciprocals is just the sum of reciprocals.----I'm not sure if I answered your question "how would you have solved it?" If you want to know how I would have set up the integral, I would have set it up the way you did. If you want to know how I would have
Dell
590
given the capacitator C1 filled with dialectric subtances, which change linearly from ε1 to ε2, what is the capacitance of C1?
since i know that ε changes linerly, according to the distance between the plates, and i know that at x=0 ε=ε1 and x=d ε=ε2
εr=ax+b
εr1=a*0+b
b=ε1
εr2=a*d+ε1
a=(ε21)/d
εr=(ε21)x/d+ε1
εr=((ε21)x+ε1d)/d
know this capacitator C1 is like millions of tiny little capacitators, dC, each with dialectric substance changing like εr=((ε21)x+ε1d)/d, all connected in a column,
1/Cp=[tex]\int[/tex]d/(Aε0εr)d(εr) from (ε1 to ε2)
=d/(Aε0)[tex]\int[/tex]d(d/((ε21)x+ε1d))
=d2/(Aε0)[tex]\int[/tex]dx/((ε21)x+ε1d) (from 0 to d)
=d2/(Aε0)*1/(ε21)* ln((ε21)x+ε1d)|from 0 to d
=[d2ln(ε21)]/ε021)Aε0
but the correct answer is meant to be 1/Cp=[dln(ε21)]/ε021)Aε0
can anyone see whre i went wrong?
εr=ax+b
εr1=a*0+b
b=ε1
εr2=a*d+ε1
a=(ε21)/d
εr=(ε21)x/d+ε1
εr=((ε21)x+ε1d)/d
1/Cp=d/(Aε0εr)d(εr) from (ε1 to ε2)
=d/(Aε0)d(d/((ε21)x+ε1d))
While I don't exactly follow what you are doing, it appears that your extra factor of d first appears here.
Just as a general rule, I wouldn't name a variable d if integration will be involved in solving the problem. Too easy to lose track of which is the variable d, and which is used to denote the variable of integration.
=d2/(Aε0)dx/((ε21)x+ε1d) (from 0 to d)
thats exactly right, the problem comes from the fact that i already have one 'd' and my εr is also dependant on 'd' εr=((ε2-ε1)x+ε1d)/d and that's where the second factor comes from, but i cannot see why this should be incorrect mathematically.
I would have set up the integral differently to begin with. What is 1/C for a slab of thickness dx? (d→differential, not capacitor thickness here) Then add them by doing the appropriate integral, as you are aware. It's not clear to me how you got the first integral you wrote.
p.s. there is a problem with the "correct" answer you quoted,
1/Cp=[d ln(ε21)] / [ε021) A ε0],​
because the units are inconsistent.
and the units of my answer??
It would be beneficial for you to work that out. They should come out to be 1/F.
I'll offer this hint:
The quantity d / (A ε0) has the correct units of 1/Farads. So any remaining terms should, overall, be unitless.
d / (A ε0) = 1/F
d2ln(ε2/ε1)]/(ε2-ε1)Aε0=d/(A ε0)* (d*ln(ε2/ε1)/(ε2/ε1))
what would the units of (d*ln(ε2/ε1)/(ε2/ε1)) be
The ε's are all unitless, leaving ... ?
so i get m/F,
but you said that there was a problem with the "correct " answers units, as far as i see they come to 1/F
1/Cp=[dln(ε2/ε1)]/(ε2-ε1)Aε0
i just saw that i wrote
1/Cp=[dln(ε2/ε1)]/ε0(ε2-ε1)Aε0
and there is an extra ε0, but you said that they are unitless
e0 does have units, e1 and e2 do not.
So, the "correct" answer has the correct units afterall.
so how would you have solved it?
the capacitance you spoke of would be
1/C=dx/(ε0εrA)
=dx/(ε0((ε2-ε1)x+ε1D)/D)A)
i used D for the distance
= D/(ε0A)∫dx/((ε21)x+ε1D)
=D/(ε0A(ε21)) * [ln(ε21)]
if i would not have taken 1/C but instead C, why would i not reach the correct answer,
The slabs of thickness dx act as many capacitors in series.
For capacitors in series, we add the reciprocals of capacitance to get total capacitance.
Oh, I forgot to say in my last post ... I would do exactly what you did here:
1/C=dx/(ε0εrA)
FAQ: Finding the capcitance of this capacitator
What is capacitance?
Capacitance is the ability of a capacitor to store electrical charge. It is measured in units of Farads (F) and is determined by the physical characteristics of the capacitor, such as its size and materials used.
How do you find the capacitance of a capacitor?
To find the capacitance of a capacitor, you can use the formula C = Q/V, where C is the capacitance in Farads, Q is the charge stored on the capacitor in Coulombs, and V is the voltage across the capacitor in Volts. This formula can also be rearranged to solve for Q or V, depending on the information given.
What factors affect the capacitance of a capacitor?
The capacitance of a capacitor is affected by factors such as the distance between the two conducting plates, the area of the plates, and the type of dielectric material used between the plates. Generally, a larger distance between plates and a larger plate area will result in a higher capacitance.
Can the capacitance of a capacitor change over time?
The capacitance of a capacitor is a constant value determined by its physical characteristics and does not change over time. However, external factors such as temperature or voltage can affect the performance of a capacitor, which may make it appear as though the capacitance has changed.
How do you measure the capacitance of a capacitor?
The most common way to measure the capacitance of a capacitor is by using a multimeter, which can measure the voltage and charge of the capacitor. There are also specialized capacitance meters that can provide a more accurate measurement. Additionally, the capacitance can be calculated using known values of charge and voltage, as mentioned in the first answer.
