Finding the change in mass of a charged body if it loses 1 C
In summary: I'm not sure.I don't understand a lot of physics, but in this question if the body loses 1C of electrons, and 1C of electrons are 6.642E18 electrons, then you has the electron mass above in the statement of problem... Can you now solve this problem?No. See this:1 coulomb = 6.642*10^18 elementary charges.
SimpleBurrito
The mass of an electron is 9*10^-31kg. Find the charge in mass of a charged body if it loses 1 Coulomb of negative charge. Use your answer to explain why electricity was originally thought to be weight less.
Everything given in question is above.
Since we know that charging of a body depends upon transfer of electrons. So, if a body becomes negatively charged it will gain electrons that is its mass will increase and if a body becomes positively charged it loses electrons hence its mass will decrease. Don’t know where to start with formulas etc. help would be appreciated.
Here you are losing negative charge, thus losing electrons. How many are lost? What total mass is lost?
I’m not sure. Are there formulas for it?
That's one key fact. (Consider an electron to be an elementary charge.)
I don't understand a lot of physics, but in this question if the body losses 1C of electrons, and 1C of electrons are 6.642E18 electrons, then you has the electron mass above in the statement of problem... Can you now solve this problem?
I do not know if maybe there is an error in my reasoning. ; -)
I’m really not sure where to start with calculations, and it’s due tomorrow. If you’ve worked it out how’d you do it?
Can you answer this? How many electrons were removed from the charged body?
does it lose 6.642*10^-31 electrons?
if it does how do I find out how much that weighs in kg's?
No. See this:
Once you get the correct number of electrons, you can make use of the mass of each electron (which is given) to find the total mass.
What’s the mass of the charged body?
Doc Al said:
No. See this:
How? I don’t understand
Alright I got 6*10^-12 is that right ?
That wasn't specified, which makes the problem somewhat ambiguous.
In kg, that would be correct. (Don't forget units!)
Mass of electrons lost = (Number of electrons lost) X (mass of each electron)
How does that mass compare to the mass of an "everyday" object?
Related to Finding the change in mass of a charged body if it loses 1 C
What is the equation for finding the change in mass of a charged body if it loses 1 C?
The equation is Δm = Q/ΔV, where Δm is the change in mass, Q is the charge lost, and ΔV is the change in velocity.
How is the change in mass of a charged body related to its charge and velocity?
The change in mass is directly proportional to the charge lost and inversely proportional to the change in velocity.
Why is there a change in mass when a charged body loses 1 C?
This change in mass is due to the conversion of electrical potential energy to kinetic energy as the charged body loses 1 C of charge.
What is the unit of measurement for the change in mass of a charged body?
The change in mass is typically measured in kilograms (kg) or grams (g).
Can the equation for finding the change in mass of a charged body be used for any type of charged body?
Yes, the equation can be used for any type of charged body, as long as the charge lost and change in velocity are known.
