Finding the coefficients of a Resistance vs. Temp curve
To find the coefficients Ro, a, and b for a Resistance vs. Temperature curve, the problem requires measurements at the ice, steam, and sulfur points. The initial calculation shows Ro equals 7 ohms at 0°C, leading to a system of equations for the other two temperatures. The challenge arises because the coefficients for a and b are not easily cancelable, complicating the solution process. After some confusion, the user resolves the issue, noting that their linear algebra course did not cover such scenarios. The discussion highlights the differences in problem-solving approaches between mathematicians and physicists.
guyvsdcsniper
Find Ro, a, and b.
R(T) = Ro (1 + aT + bT2 )
I am asked to find Ro, a, and b. Th problem states the values are determined by the measurements at the normal ice, steam and sulfur points. So I approached the problem by plugging the the temperature problems. For 0°C, Ro reduces to 7 ohms. Then for the other two non zero temperatures, it looks like I am left with a system of equations.
I am a bit stumbled because the values associated for a and b of both equations arent factors of each other, so canceling out seems a bit trickier. I don't really recall running across a problem like this before.
Am I approaching this problem correctly? If so what is a way to solve for a and b?
You have three temperatures which means that you can write three equations, one at each temperature, and three unknowns. The first equation gives you (as you have already found) R0 = 7 Ω. Use that value in the other two equations which form a system of 2 equations and 2 unknowns a and b. Can you solve that?
I figured it out. I actually just finished a linear algebra course and they never gave us a problem like that where the coefficients weren't perfect factors of each other.
Very noob post. Sorry lol
Yes, but don't berate yourself. You were led up the garden path. Mathematicians sometimes have a different view of the world from physicists.
Likes guyvsdcsniper
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
