Finding the determinant of a matrix using determinant properties
In summary: So ##\begin{vmatrix}a_1 & a_2 & a_3\\b_1 & b_2 & b_3\\0 & 0& k\end{vmatrix} = k## and so the determinant is k.
Bolter
262
31
See below
None
Hi, I have been having some trouble in finding the determinant of matrix A in this Q
Which relevant determinant property should I make use of to help me find the determinant of matrix A and maybe matrix B also
This is what I have tried for matrix A so far but it's not much help really
Any help would be much appreciated! Thanks
What you have assumed is definitely not a property of the determinant: ##det(X + Y) \ne det(X) + det(Y)##. Absolutely not!
The determinant properties the problem is talking about are row operations or column operations.
If you swap two rows, it changes the sign of the determinant.
If you replace a row by itself + another row, the value remains the same.
If you replace a row by itself times a nonzero constant multiple, the value of the determinant gets multiplied by that value.
The column operations are similar, with "row" above replaced by "column".
Likes archaic
I thought I was using the addition property which I saw in my notes
Apologies, I missed what you had done there.
If you replace a row by a nonzero multiple of itself, the value remains the same.
Edit: If you replace a row by itself times a nonzero constant multiple, the value of the determinant gets multiplied by that value.
For the last bit "If you replace a row by a nonzero multiple of itself, the value remains the same." is that the same as saying if one of the row of a matrix is multiplied by a factor, then the determinant of the matrix will be multiplied by this factor.
as in this rule?
Also I'm not sure which property to start off with which will help me identify what the determinant will be
No worries! Just a bit confused which property I can firstly use that will help break down the matrix to a simpler one so I can find the determinant
I should have said that the value of the determinant is multiplied by the value of that multiple; i.e., if you multiply a row by a constant k, the determinant will be multiplied by the same amount.
I'll edit my earlier reply.
Regarding your work in post #1. What happens if you add row 2 to row 1?
For your first example I would do $$
\begin{vmatrix}
y+z & z+x & x+y\\
x & y & z\\
1 & 1& 1
\end{vmatrix} =
\begin{vmatrix}
x+y+z & x+y+z & x+y+z\\
x & y & z\\
1 & 1& 1
\end{vmatrix}
$$That's just a matrix with determinant of the form ##
\begin{vmatrix}
a & a & a\\
b_1 & b_2 & b_3 \\
c & c& c
\end{vmatrix}##.
Likes archaic and PeroK
NB etothepi did a part for you - he doesn't mean stop there. :oldsmile:
As well as the rules in #3 there is also one about linear combination of rows or of columns which is surely in your textbook, with illustrative examples.
Likes etotheipi
\begin{vmatrix}
y+z & z+x & x+y\\
x & y & z\\
1 & 1& 1
\end{vmatrix} =
\begin{vmatrix}
x & y & z\\
1 & 1& 1
\end{vmatrix}
\begin{vmatrix}
a & a & a\\
b_1 & b_2 & b_3 \\
c & c& c
\end{vmatrix}##.
Hi, I can see what you have did here
So the steps are...
Add row 2 to row 1 which you have shown
then I can multiply row 3 by x+y+z
That gives row 1 and 3 to be identical
then minus row 1 from row 3 to get a zero row
Having a zero row would give a zero determinant. Is that ok?
That's fine. If ##
\begin{vmatrix}
a & a & a\\
b_1 & b_2 & b_3 \\
c & c& c
\end{vmatrix} = k## for non-zero ##a## & ##c##, then ##\begin{vmatrix}
a & a & a\\
b_1 & b_2 & b_3 \\
a & a& a
\end{vmatrix} = \frac{ak}{c}##. Switching the first and third rows should negate the sign, however evidently you'd just end up with the same matrix, which means that its determinant must be zero. It follows that ##\frac{ak}{c} = 0 \implies k=0##.
Likes Bolter
Yes. You can determine this in two ways:
1) Using whatever technique you have for evaluating a determinant.
2) If ##\begin{vmatrix}a_1 & a_2 & a_3\\
b_1 & b_2 & b_3 \\0 & 0& 0\end{vmatrix} = D##, then multiplying the third row by nonzero k leaves the values in the third row unchanged, but changes the value of the determinant to kD.
##k\begin{vmatrix}a_1 & a_2 & a_3\\
kD##
Since the matrix we're taking the determinant is the same, it must be that kD = D, or D(k - 1) = 0. So either k = 1 or D = 0. The choice of k is completely arbitrary, so it must be that D = 0.
Likes Bolter
Related to Finding the determinant of a matrix using determinant properties
What is the determinant of a matrix?
The determinant of a matrix is a scalar value that can be calculated from the elements of the matrix. It is used to determine whether a matrix has an inverse and is also used in solving systems of linear equations.
How do I find the determinant of a matrix?
To find the determinant of a matrix, you can use determinant properties such as expanding along a row or column, or using cofactor expansion. These methods involve using the elements of the matrix to calculate the determinant.
What are the properties of determinants that can be used to find the determinant of a matrix?
Some of the properties of determinants that can be used to find the determinant of a matrix include the fact that the determinant of a matrix is equal to the product of its eigenvalues, and that the determinant of a triangular matrix is equal to the product of its diagonal elements.
Why is it important to use determinant properties when finding the determinant of a matrix?
Using determinant properties can make it easier and more efficient to find the determinant of a matrix. It can also help in understanding the underlying concepts and principles behind the calculation of determinants.
Can determinant properties be used for matrices of any size?
Yes, determinant properties can be used for matrices of any size as long as the matrix is square (i.e. has the same number of rows and columns).
  • Linear and Abstract Algebra
