MHB Finding the difference of mixed measures
  • Thread starter Thread starter clhrhrklsr
    Difference Mixed
To solve the problem of subtracting mixed measures, first, borrow one degree from the top line, converting it to minutes, resulting in 18 degrees 77 minutes 33 seconds. The next step is to subtract the second measure, 7 degrees 45 minutes 28 seconds, from this adjusted value. The subtraction can be performed by aligning the degrees, minutes, and seconds separately. After completing the subtraction, the final result will provide the difference in mixed measures. This method effectively simplifies the calculation process for mixed units.
clhrhrklsr
How would I work the following problem-19(degrees) 17' 33"
- 7(degrees) 45' 28"Please help asap
Mathematics news on Phys.org
We are given:
$$\begin{array}{r}19^{\circ}\,17^{\prime}\,33^{\prime\prime} \\ -\,\underline{\,\,7^{\circ}\,45^{\prime}\,28^{\prime\prime}}\end{array}$$
If, in the top line, we "borrow" a degree, and add it to the minutes, we have:
$$\begin{array}{r}18^{\circ}\,77^{\prime}\,33^{\prime\prime} \\ -\,\underline{\,\,7^{\circ}\,45^{\prime}\,28^{\prime\prime}}\end{array}$$
Now we can just subtract like terms...can you proceed?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
