Finding the direction of forces
To accurately represent tension in a free body diagram (FBD), place the tail of the tension arrow at the center of mass if treating the object as a point mass. For extended bodies, position the tail at the attachment point of the string or rope. The arrow's shaft should be parallel to the taut string, with the head pointing away from the object, as ropes cannot push. If further clarification is needed, participants are encouraged to ask additional questions. Understanding these principles is crucial for correctly analyzing forces in physics.
grade11studentgoaat
how can i easily find the forces direction like if i said a kid was pulling 10lb[W] where would i put the tension in the free body diagram
nothing
Tension force = 10lb[W] where do i put tension arrow in the full body diagram
You're welcome. After reading through that article, if you still have questions please post them here and we will try to help you understand FBDs.
To draw an arrow representing tension:
  • If you treat the system as a point mass, put the tail of the arrow roughly at the center of mass of the object. If it is an extended body and you need to calculate torques, then it would be correct to put the tail of the arrow at the point where the string or rope is attached to the object.
  • The shaft of the arrow should be drawn parallel to the taut string or rope.
  • The head of the arrow should always point away from the object. That's because you cannot push with a rope.
I hope this helps.
On the free body diagram of what body?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
