Finding the distance between a point and a line
  • MHB
  • Thread starter MarkFL
  • Tags
    Line Point
In summary, the formula for finding the distance between a point and a line is d = |Ax0 + By0 + C| / √(A^2 + B^2). A point is considered on a line if it satisfies the equation Ax0 + By0 + C = 0. The distance between a point and a line is always positive, and differs from finding the distance between two points as it involves finding the shortest distance between a single point and a line. It is possible for the distance between a point and a line to be greater than the distance between two points if the point is not directly above or below the line.
MarkFL
MHB
13,288
In analytic or coordinate geometry, we are often asked to work problems that involve using the perpendicular (shortest) distance between a point and a line in the plane. Here are two methods to find this distance:
Method 1:
In the xy plane, we have a point $\displaystyle P_0\left(x_0,y_0 \right)$ separated from a line $\displaystyle y=mx+b$ by some distance $\displaystyle d>0$.
Extend a line segment from the point to the line such that the segment intersects perpendicularly with the line y. Label this segment d.
Now extend a vertical line segment from the point to the line and we find its length is $\displaystyle a=\left|mx_0+b-y_0 \right|$ (using $\displaystyle y\left(x_0 \right)-y_0$).
Next, extend a horizontal line segment from the point to the line and we find its length is $\displaystyle c=\left|x_0-\frac{y_0-b}{m} \right|$ (using $\displaystyle x_0-x\left(y_0 \right)$) thus:
$\displaystyle c=\left|\frac{mx_0+b-y_0}{m} \right|=\frac{a}{|m|}$
Please refer to the diagram:
By similarity, we have:
$\displaystyle \frac{d}{c}=\frac{\sqrt{a^2-d^2}}{a}$
$\displaystyle \frac{d}{\sqrt{a^2-d^2}}=\frac{c}{a}=\left|\frac{1}{m} \right|$
$\displaystyle \frac{d^2}{a^2-d^2}=\frac{1}{m^2}\:\therefore\:d^2=\frac{a^2}{m^2+1}\:\therefore\:d=\frac{a}{\sqrt{m^2+1}}$
Thus, we have:
$\displaystyle d=\frac{\left|mx_0+b-y_0 \right|}{\sqrt{m^2+1}}$
Method 2:
First, we find that the line perpendicular to $\displaystyle y=mx+b$ and passing through $\displaystyle P_0$ is:
$\displaystyle y=-\frac{1}{m}\left(x-x_0 \right)+y_0$
Solving the resulting linear system we find the common point to both lines is:
$\displaystyle \left(\frac{x_0+m\left(y_0-b \right)}{m^2+1},\frac{m\left(x_0+my_0 \right)+b}{m^2+1} \right)$
Now, using the distance formula for $\displaystyle P_0$ to the above point, we find:
$\displaystyle d=\sqrt{\left(x_0-\frac{x_0+m\left(y_0-b \right)}{m^2+1} \right)^2+\left(y_0-\frac{m\left(x_0+my_0 \right)+b}{m^2+1} \right)^2}$
The reader should verify that this reduces to:
Comments and questions should be posted here:
http://mathhelpboards.com/commentary-threads-53/commentary-finding-distance-between-point-line-5966.html
This topic is for comments/questions pertaining to this tutorial:
http://mathhelpboards.com/math-notes-49/finding-distance-between-point-line-2952.html
There is another nice way to do it.
Let $C$ be the circle $(x-x_0)^2+(y-y_0^2)=r^2$ centered at $P$ and having radius $r$. The line $y=mx+b$ can have two points in common or one point in common or no points on common with $C$. Assume $m\neq 0$ because if it is then the answer is easily found. The perpendicular distance from $P$ to $y=mx+b$ is equal to the radius $r$ corresponding to which there is exactly one point in common between $y=mx+b$ and $C$. For this we substitute $x=(y-b)/m$ in $C$ and find a quadratic in $y$. For having just one root of this we just need to set the discriminant to zero and find the desired result.
I suggest the following proof that deals with the general (or standard) form of the line equation rather than the slope–intercept form.
Suppose in a Cartesian coordinate system a line $l$ is given by the equation $L(x,y)=0$ where $L(x)=Ax+By+C$. Also, let $\vec{n}=(A,B)$.
Theorem. The distance $d(P_0,l)$ from any point $P_0(x_0,y_0)$ to $l$ is $L(x_0,y_0)/|\vec{n}|$.
Proof. Let $P_1(x_1,y_1)$ be any point on $l$ (thus, $L(x_1,y_1)=0$) and let $\varphi$ be the (smaller) angle between $\overrightarrow{P_1P_0}$ and $\vec{n}$. Since $\vec{n}$ is perpendicular to $l$ (Lemma 2 below), we have
\begin{align*}
d(P_0,l)&= |\overrightarrow{P_1P_0}|\cdot|\cos\varphi|\\
&=\frac{|\overrightarrow{P_1P_0}\cdot\vec{n}|} {|\vec{n}|}\\
&= \frac{|A(x_0-x_1)+B(y_0-y_1|)}{|\vec{n}|}\\
&=\frac{|L(x_0,y_0)-L(x_1,y_1)|}{|\vec{n}|}\\
&=\frac{|L(x_0,y_0)|}{|\vec{n}|}
\end{align*}
Since $|\vec{n}|=\sqrt{A^2+B^2}$, $d(P_0,l)$ can be expanded to
\frac{|Ax_0+By_0+C|}{\sqrt{A^2+B^2}}
Lemma 1. Vector $(-B,A)$ is parallel to $l$. This holds in any affine coordinate system, not necessarily a Cartesian one.
Proof. Let $P_0(x_0,y_0)$, $P_1(x_1,y_1)$ be two different points on $l$. Then $\overrightarrow{P_0P_1}=(x_1-x_0,y_1-y_0)$ is parallel to $l$. Also,
L(x_1,y_1)-L(x_1,y_1)=A(x_1-x_0)+B(y_1-y_0)=0
or
A(x_1-x_0)=-B(y_1-y_0)\tag{*}
If $A\ne0$ and $B\ne0$, then (*) is equivalent to
\frac{x_1-x_0}{-B}=\frac{y_1-y_0}{A}
But even if $A=0$ or $B=0$ (but not $A=B=0$), (*) expresses the fact that $(x_1-x_0,y_1-y_0)$ is proportional to, and thus parallel to, $(-B,A)$.
Lemma 2. If the coordinate system is Cartesian, then $n$ is perpendicular to $l$.
Proof. By Lemma 1, vector $\vec{p}=(-B,A)$ is parallel to $l$, and $\vec{n}\cdot\vec{p}=-AB+BA=0$, so $n$ is perpendicular to $p$ and to $l$.
FAQ: Finding the distance between a point and a line
What is the formula for finding the distance between a point and a line?
The formula for finding the distance between a point (x0, y0) and a line Ax + By + C = 0 is:
How do you determine if a point is on a given line?
A point (x0, y0) is on a line Ax + By + C = 0 if the equation is satisfied, meaning:
Ax0 + By0 + C = 0
Can the distance between a point and a line be negative?
No, the distance between a point and a line is always positive as it represents the shortest distance between the point and the line.
How does finding the distance between a point and a line differ from finding the distance between two points?
Finding the distance between a point and a line involves finding the shortest distance between a single point and a line in a coordinate plane. In contrast, finding the distance between two points involves finding the length of the line segment connecting two points in a coordinate plane.
Can the distance between a point and a line be greater than the distance between two points?
Yes, it is possible for the distance between a point and a line to be greater than the distance between two points. This occurs when the point is not directly above or below the line, causing the distance to be longer as it forms a diagonal line.
