MHB Finding the Distance from Point P to AC on an ABCD.EFGH Cube
  • Thread starter Thread starter Monoxdifly
    Ac Cube Point
The discussion centers on finding the distance from point P to line AC in an ABCD.EFGH cube with a side length of 8 cm. Initially, there was confusion regarding the placement of point P, which was clarified to be within AH. The coordinates for the vertices of the cube were established, leading to the calculation of point P as (8,6,6). The distance from P to AC was determined using calculus, resulting in a minimum distance of 3√6 cm. Alternative methods, such as algebraic manipulation and trigonometry, were also mentioned as valid approaches to solving the problem.
Monoxdifly
MHB
Given an ABCD.EFGH cube whose its side length is 8 cm. The point P is within AB so that AP = 3PH. The distance between P to AC is ...
A. $$2\sqrt3$$ cm
B. $$3\sqrt3$$ cm
C. $$2\sqrt6$$ cm
D. $$3\sqrt6$$ cm
E. $$4\sqrt6$$ cm
So AH is $$8\sqrt2$$ cm and PH = $$6\sqrt2$$. What do I do now? Is the triangle HPC a right triangle?
Mathematics news on Phys.org
A. $$2\sqrt3$$ cm
B. $$3\sqrt3$$ cm
C. $$2\sqrt6$$ cm
D. $$3\sqrt6$$ cm
E. $$4\sqrt6$$ cm
This sounds wrong. If P lies on AB then it must be closer to A than to H. So the condition AP = 3PH is impossible.
Sorry, I meant P is within AH. Sigh, why did I make a lot of typos last night?
My method is to use coordinates, taking the vertices of the cube as
$A = (8,0,0),$
$B = (0,0,0),$
$C = (0,8,0),$
$D = (8,8,0),$
$E = (8,0,8),$
$F = (0,0,8),$
$G = (0,8,8),$
$H = (8,8,8).$
(Of course, that is not the only way to assign the vertices. I was working from a sketch in which it was convenient to take $B$ as the origin.)
The point $P$ is then $(8,6,6)$. A point on $AC$ is given by $(t,8-t,0)$. The distance $d$ from that point to $P$ satisfies $d^2 = (t-8)^2 + (2-t)^2 + 6^2$. If you minimise that by calculus, you find that $t=5$, and $d = 3\sqrt6$.
Edit. If you don't want to use calculus, you can do it algebraically by completing the square: $$d^2 = (t-8)^2 + (2-t)^2 + 6^2 = 2t^2 - 20t + 104 = 2(t-5)^2 + 54.$$ That clearly has minimum value 54, when $t=5$. So $d = \sqrt{54} = 3\sqrt6$.
I ended up solving the problem with trigonometry instead of algebra and calculus. Thanks, anyway. It's always nice to see different approaches.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
