Finding the domain of a composite function
In summary, In this problem, the solution is not found using the definition of composite function. However, @Mark44 shows another way to solve the problem that is valid only if x ≠ 2/3.
member 731016
Pls see below
Pls see below
For this problem,
The solution is,
However, I tried solving this problem by using the definition of composite function
##f(g(x)) = f(\frac{4}{3x -2}) = \frac{5}{\frac{4}{3x - 2} - 1} = \frac{5}{\frac{6 - 3x}{3x - 2}} = \frac {15x - 10}{6 - 3x}## which only gives a domain ##x ≠ 2##. Would some please know how to find the solution from the composite function?
Many thanks!
Consider: [tex]
\frac{5}{\frac{4}{3x-2}-1} = \frac{5(3x-2)}{\left(\frac{4}{3x-2}-1\right)(3x-2)}.[/tex] This is fine if [itex]x \neq 2/3[/itex], but if [itex]x = 2/3[/itex] then multiplying numerator and denominator by [itex]3x - 2[/itex] is multiplying numerator and denominator by zero, which is not allowed.
Likes member 731016 and FactChecker
pasmith said:
Consider: [tex]
Thank you for your reply @pasmith!
Sorry, why did you not multiply ##\frac{4}{3x - 2}## individually by the ##\frac{3x-2}{3x-2}##?
Many thanks!
Here's from your work:
Callumnc1 said:
However, I tried solving this problem by using the definition of composite function ##f(g(x)) = f(\frac{4}{3x -2})##
What do you get if x = 2/3 when you evaluate f(g(2/3))?
Likes member 731016
Callumnc1 said:
pasmith said:
Consider: [tex]
Many thanks!
Sure. If you distribute the ##(3x-2)## in the denominator and then simplify by "cancelling" and collecting terms, you will indeed get ## \dfrac {15x - 10}{6 - 3x}## which is ## \dfrac {5(3x - 2)}{3(2 - x)}## .
However, the point made by @pasmith is that the step he shows, which is required to get your final result;
that step is valid, only if ##x\ne \dfrac 2 3 ##.
@Mark44 shows in a different way, why ##x\ne \dfrac 2 3 ##.
If you study the given solution (the one you posted) seriously, you should notice that the first sentence there says much the same thing as Mark says.
Likes member 731016
Thank you for your reply @Mark44!
I think I get undefined. However, I thought we were meant to simplify the composite function to that rational function in post #1 before substituting in values?
Many thanks!
Thank you for your reply @SammyS!
I think I understand @pasmith method now! I guess it interesting that he did not simplify the fraction at first to see what values it was zero for, and then to find the other x-value you have to reduce it more to get the rational function I got. I guess this is interesting. Is there a way to remember this technique? I have not seen it in my calculus textbook.
With other composite function problems (without fractions) I have done, I just had to find the x-values that would not work for the final answer without having to do that in intermediate steps.
Many thanks!
No, not quite. You're asked to find the domain of f(g(x)), which means you have to find values of x for which g(x) is undefined, and values of g(x) for which f is undefined. These values will determine the domain of f(g(x)).
Likes member 731016
Well, for those problems, it looks like you were simply fortunate.
Likes member 731016
Thank you for your help @Mark44!
Thank you for your help @SammyS! Oh ok, that's quite interesting because I solved quite a few of them using that method.
Many thanks!
FAQ: Finding the domain of a composite function
What is a composite function?
A composite function is a function that is formed by combining two functions. If you have two functions, f(x) and g(x), the composite function is written as (f ∘ g)(x), which means f(g(x)). This involves applying g first and then applying f to the result of g.
How do you find the domain of a composite function?
To find the domain of a composite function (f ∘ g)(x), you need to follow these steps:1. Determine the domain of the inner function g(x).2. Find the domain of the outer function f(x).3. Ensure that the values from the domain of g(x) map to values within the domain of f(x). The composite function's domain is the set of all x values that satisfy these conditions.
Why is the domain of the inner function important?
The domain of the inner function g(x) is crucial because it determines the initial set of values that can be input into the composite function. If x is not in the domain of g, then g(x) is undefined, and consequently, (f ∘ g)(x) is also undefined.
What if the inner function produces values outside the domain of the outer function?
If the inner function g(x) produces values that are not within the domain of the outer function f(x), then those values must be excluded from the domain of the composite function. This is because f cannot be applied to values outside its domain, making (f ∘ g)(x) undefined for those inputs.
Can you provide an example of finding the domain of a composite function?
Sure! Let's consider two functions, f(x) = √x and g(x) = x - 1. The composite function is (f ∘ g)(x) = f(g(x)) = √(x - 1).1. The domain of g(x) = x - 1 is all real numbers, since any real number can be input into g.2. The domain of f(x) = √x is x ≥ 0, since the square root function is only defined for non-negative numbers.3. For (f ∘ g)(x) to be defined, g(x) must produce values that are within the domain of f. Therefore, x - 1 ≥ 0, which simplifies to x ≥ 1.Thus, the domain of the composite function (f ∘ g)(x) is x ≥ 1.
